Hello..
My teacher asked me to write a program for line following robot again in a simpler and a easy way USING 2051MICRORONTROLLER. So I tried... and this is what I have formed.... Can anyone please tell me IF I am wrong anywhere or if I need to change my program anyhow??
ORG 00H
LJMP START
ORG 30H
START: MOV P1.6,#1B ; CONFIG P1.6 AS I/P PIN
MOV C,P1.6 ; I HAVE CONNECTED A S/W HERE TO START THE ROBOT
JC STOP
MOV P3,#3CH ;4 SENSOR INPUTS ARE CONNECTED AT P3.5,P3.4,P3.3 AND P3.2
MOV P1,#00H ;CONFIG AS O/P PORT
CLR A
AGAIN: MOV A,P3
ANL A,#14H ; CHECK IF FRONT ON BACK SENSOR ARE ON
JB P3.3,CHECK_LEFT ; CHECK IF LEFT SIDE SENSOR IS ON
JB P3.5,CHECK_RIGHT ; CHECK IF RIGHT SIDE SENSOR IS ON
CJNE A,#14H,STOP ; CHECK IF FRONT ON BACK SENSOR ARE ON
SETB P1.0 ; ENABLE 1 OF L293D MOTOR DRIVER IC
SETB P1.1 ;ENABLE 2 OF L293D MOTOR DRIVER IC
SETB P1.2 ;ROTATE RIGHT MOTOR IN CLOCKWISE DIRECTION
CLR P1.3 ;ROTATE RIGHT MOTOR IN CLOCKWISE DIRECTION
SETB P1.4 ;ROTATE LEFT MOTOR IN CLOCKWISE DIRECTION
CLR P1.3 ;ROTATE LEFT MOTOR IN CLOCKWISE DIRECTION
AJMP AGAIN
CHECK_LEFT:
MOV A,P3
ANL A, #08H
CJNE A,#08H,AGAIN ;RECHECK IF LEFT SIDE SENSOR IS ON
CLR P1.4 ;ROTATE LEFT MOTOR IN ANTICLOCKWISE DIRECTION
SETB P1.3 ;ROTATE LEFT MOTOR IN ANTICLOCKWISE DIRECTION
ACALL DELAY
AJMP AGAIN
CHECK_RIGHT:
MOV A,P3
ANL A, #20H
CJNE A,#20H,AGAIN ;RECHECK IF LEFT SIDE SENSOR IS ON
CLR P1.2 ;ROTATE RIGHT MOTOR IN ANTICLOCKWISE DIRECTION
SETB P1.3 ;ROTATE RIGHT MOTOR IN ANTICLOCKWISE DIRECTION
ACALL DELAY
AJMP AGAIN
DELAY:
CLR TF0
MOV R0,#14H
L1: MOV TL0,#00H
MOV TH0, #4CH
SETB TR0
L2: JNB TF0,L2
CLR TR0
CLR TF0
DJNZ R0,L1
RET
STOP:
MOV A,P3
ANL A, #3CH
CJNE A,#00H,AGAIN ; RE-RCHECK IF ANY SENSOR ON
SETB P1.2 ; STOP RIGHT MOTOR
SETB P1.3 ; STOP RIGHT MOTOR
SETB P1.4 ; STOP LEFT MOTOR
SETB P1.5 ; STOP LEFT MOTOR
END
