The package is SOT23-5.
If you search the internet you will find lots of components in this package. But unless you have no info about the component, it is impossible to go any further.
I've never seen.
Maybe the people who sold you the board have the "PAY" word marked on the chip.
Has this chip anything to do with the seller or the producer?
So there are 3 points to consider: IN, OUT and V+.
Study these pins and you'll get the answer to the question that what really it is. If we hadn't the V+, I could tell you that its a regulator.
I haven't got some schematic, if I had I make a detection of the diagram and then his replacement.
Picture of the SMD component is not possible, it is small and hidden. But the above picture corresponds to reality. And this unit is manufactured after 2007.
The pin mapping suggests a driver similar to TPS2828 or 29. TI lists a marking of PAY and an additional fourth letter for TPS2829 (non-invertig MOSFET driver).
i found these components for PA smd code with the footprint you've sent (the last letter may be extra information like manufacturing company identifier):
BD5240FVE voltage detector 4V reset open drain output
BD5240G voltage detector 4v,reset open drain output
BH15PB1WHFV LDO,CE,1.5V,150mA
check to see which is your case(by testing the the known signal passes like vcc gnd , ...)
hope to be useful.
For user FvM: I checked the SMD components TPS2828 you recommend me, but I not found in datasheet that has the marking code PAY. Please could you sent me the documents by which you found the SMD component. Thank you in advance.
