1050744
Newbie level 3
hi all
I need ur service to make comments on the following code (explain each line in the code). and please send the comments on the following mail:
abu_alrub1987@yahoo.com
thnx alot
the code is for ISD4003:
ISD4003 Code:
/* PREPROCESSOR STUFF */
#case
#include <16F877a.H>
/* clk is 20MHz */
#use Delay(Clock=20000000)
/* no watchdog timer, no code protect, yes power up timer */
#fuses HS, NOWDT, NOPROTECT, PUT
/* set port directions manually */
#use fast_io(A)
#use fast_io(B)
#define LED_1 PIN_B6
#define LED_2 PIN_B7
#define VOICE_SS PIN_B3
#define PUSH_REC PIN_A1
#define PUSH_PLAY PIN_A4
#define PUSH_STOP PIN_A5
#define T_PUD 25 /* Power Up Delay Time to wait ( miliseconds ) */
#define POWER_UP_CMD 0b00100000
#define POWER_DN_CMD 0b00010000
#define STRT_RECORD_CMD 0b10110000
#define STOP_RECORD_CMD 0b00110000
#define STRT_PLAY_CMD 0b11110000
#define STOP_PLAY_CMD 0b00110000
#define INIT_MSG_CUE_CMD 0b11101000
#define STRT_MSG_CUE_CMD 0b11111000
void power_up_voice() { /*this function is used to
give power to PIC*/
output_low(VOICE_SS); /*let pin B3 of the PIC low*/
spi_write( 0x00 ); /*blank address*/
spi_write( POWER_UP_CMD); /* Send data via SPI*/
output_high( VOICE_SS ); /*let pin B3 of the PIC high*/
delay_ms( T_PUD * 4 ); /* give some extra time to power up operation */
void power_down_voice() { /* this function is used to
decrease power of PIC*/
output_low( VOICE_SS ); /*let pin B3 of the PIC low*/
spi_write( POWER_DN_CMD ); /* Send data via SPI*/
/* Function will record at the current address
messages should be cued to the last one before initiating a new record operation
void start_record_voice() { /* to start recording your message*/
spi_write( 0x00 ); /*bLANK ADDRESS */
spi_write( STRT_RECORD_CMD ); /* send data via spi*/
void stop_record_voice() { /* for stopping recording messages*/
spi_write( STOP_RECORD_CMD ); /* send data via spi*/
delay_ms(100); /* actual time is 50ms. used 100 just in case */
void start_play_voice() { /*to start playing message*/
int i;
spi_write( STRT_PLAY_CMD ); /* send data via spi*/
delay_ms(10);
/* need to monitor for end of message interruption not done yet
will just wait for now
for (i=0;i<10;i++)
delay_ms( 1000 );
void stop_play_voice() { /*to stop playing the message*/
spi_write( STOP_PLAY_CMD ); /* send data via spi*/
/* fUNCTION that initializes cueing mode.
Jumps to the beggining of the messages.
void init_message_cue_voice() {
spi_write( 0x00 );
spi_write( INIT_MSG_CUE_CMD);
delay_ms(20);
/* Function that starts message cueing.
Will play from last message
init_message_cue_voice() has to be invoqued first to play first message
void start_message_cue_voice() {
spi_write( 0x00 );
spi_write( STRT_MSG_CUE_CMD);
delay_ms(20);
test_LED() {
output_high(LED_1); /*pin B6 of the pic will be high*/
output_low(LED_1); /* pin B6 of the pic will be low*/
delay_ms(200); /* wait for 200ms*/
void record_addr_test() {
delay_us(25);
spi_write( 0x00 );
spi_write( 0x05 ); /*inv 00000101 */
delay_us(25);
delay_us(50);
void stop_test() {
delay_us(25);
spi_write( 0x00 );
spi_write( 0x0C ); /*inv 00001100 */
delay_us(25);
delay_us(25);
void play_addr_test() {
delay_us(25);
spi_write( 0x00 );
spi_write( 0x07 ); /* 00000111 */
delay_us(25);
delay_ms(25);
void power_up_voice_test() {
/*#define POWER_UP_CMD 0b0010 0000
0000 0100 */
delay_us(25);
spi_write( 0x00 );
spi_write( 0x04 );
delay_us(25);
main()
int i;
/* INIT SEQUENCE */
/* enable timer interrupt
counter incr happens every 8M/4/128
interrupt is every 256 counts, 61 interrupts/sec */
set_rtcc(0);
setup_counters(RTCC_INTERNAL, RTCC_DIV_128);
enable_interrupts(RTCC_ZERO);
enable_interrupts(GLOBAL);
/* set direction of ports*/
set_tris_a(0b00110010);
set_tris_b(0x00);
set_tris_c(0b00010000);
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16 ); /*SPI mode 1*/
delay_ms(400);
delay_ms(400);
for(i=0;i<4;i++) test_LED();
for(i=0;i<250;i++) {
output_high(VOICE_SS);
delay_us(25);
delay_us(25);}
/* power_up_voice(); */
power_up_voice_test();
delay_ms(100);
delay_ms(400);
do{
if( input( PUSH_REC ) == 0 ) {
delay_ms(400);
/* start_record_voice(); */
record_addr_test();
output_low(LED_2);
else if ( input( PUSH_PLAY ) == 0 ) {
stop_play_voice();
init_message_cue_voice();
start_play_voice();
start_message_cue_voice();
start_play_voice();
delay_ms(400);
output_low( LED_2);
play_addr_test();
delay_ms(5000);
else if ( input( PUSH_STOP ) == 0 ) {
delay_ms(10);
stop_test();
output_high(LED_2);
test_LED();
}while(1);
thnx alot
ISD4003 Code:
#case
/* clk is 20MHz */
#use fast_io(A)
#use fast_io(B)
give power to PIC*/
int i;
delay_ms(10);
for (i=0;i<10;i++)
delay_ms( 1000 );
spi_write( 0x00 );
delay_ms(20);
spi_write( 0x00 );
delay_ms(20);
test_LED() {
delay_us(25);
spi_write( 0x00 );
delay_us(25);
delay_us(50);
void stop_test() {
delay_us(25);
spi_write( 0x00 );
delay_us(25);
delay_us(25);
delay_us(25);
spi_write( 0x00 );
delay_us(25);
delay_ms(25);
0000 0100 */
delay_us(25);
spi_write( 0x00 );
spi_write( 0x04 );
delay_us(25);
main()
int i;
/* INIT SEQUENCE */
set_rtcc(0);
set_tris_b(0x00);
delay_ms(400);
delay_ms(400);
delay_us(25);
delay_us(25);}
delay_ms(100);
delay_ms(400);
do{
delay_ms(400);
record_addr_test();
output_low(LED_2);
stop_play_voice();
start_play_voice();
start_play_voice();
delay_ms(400);
output_low( LED_2);
play_addr_test();
delay_ms(5000);
delay_ms(10);
stop_test();
output_high(LED_2);
test_LED();
}while(1);
