Platform Independent Code
Sanath Embedded
Member level 3
Hi Guys,
I am writing an program for one application in C / C++ which should run on all target controller architecture like 8051 , AVR, PIC , MSP430 or ARM7 . How could I write this Platform Independent Code.
can anyone help me on this.
you should practice writing code in layered structure.. i meant you should write hardware-dependent code and hardware-independent code separately
for example.. check below code that sends string via UART
High-Level or Hardware-independent function
void putsUART(char *str)
      while(*str)
          putcUART(*str++);
low-level or Hardware-dependent function
void putcUART(char chr)
     //hardware dependent code
Here u can use High-level function in all architectures but u have to write Low-level function seperately for each architectures..
click helped button if i helped u
