hello123456
Newbie level 3
Hi
I would like to design a planar center tapped trasnformer working the the ISM Band (2.4-2.48GHz). I was planning to realize it over a FR4 board 1.6mm thickness. I was thinking to implement it using a Frlan transformer layout in order to maximize the Km index. There´s just a problem which is the technology limit. I can fabricate maximum 0.1-0.2 mm windings width over the FR4 layer. I have read some general on chip transformer guideline (like Monolithic Transformers for Silicon RF IC Design ) but all the implementations are on microscale. My doubt is if it is possible to achieve the same performances using an FR4 board 1.6mm thick and windings with space in the order of 0.1/0.2 mm.
Any suggestions? Design procedures and steps?
Thank you so much.
Thank you so much.
