Placement of series termination.
openstm
Newbie level 5
INDIA
series termination placement
We are generating a clock from a oscillator. If we are going to drive that clock signal through a clock buffer, Where should I keep the series termination. Whether at the output of the oscillator or output of the buffer?
Please clarify and justify.
Thank you,
Siva
FvM
Super Moderator
Staff member
Bochum, Germany
frequency series termination
I don't understand the "or" in your question. The oscillator and the clock buffer output possibly need series termination, depending on the signal frequency, connected trace length and load properties.
But typically, I would expect it for the clock buffer.
rfmw
Advanced Member level 2
series termination resistor
Series-termination resistor is placed at the device output that drives a transmission line. For more info, please attach your circuit diagram.
openstm
Newbie level 5
INDIA
series termination of transmission line
Thank you for the comments..
dmd4raj
Member level 4
series termination resistor placement
Place the series termination series to source(near)for the proper temination
Regards
Rajan.K
jai_vardhan
Junior Member level 3
noida
Re: series termination resistor placement
In a 8pin SOIC Clk buffer there are total 5 clk o/p all are feeded through series resistor. Keep in mind that always series resistor tobe placed near to driver side and parellel to source side.
