[SOLVED] Place and Route in SoC Encounter
oAwad
Full Member level 2
Hello all,
I would like to know if there is an option in SoC Encounter to place&route some special cells manually (I need to specify there position in the core and do manual routing for them) and then place&route the whole design based on this ?
If yes, how to keep these special cells and there routing wires fixed during timing optimization, CTS,...etc ?
Thanks
oAwad
Full Member level 2
by special cells, I mean special instances in my synthesized gate level netlist
ThisIsNotSam
Advanced Member level 5
Yes, you can place any cell any way you want. You can do this on the GUI by dragging and dropping, or scripting it with TCL.
The process is the same: set the location first, then change the placement status from unplaced to fixed. This usually does the trick.
