signal checksum_Y : std_logic_vector(8 downto 0);
signal y_data : std_logic_vector(9 downto 0);
type did_reg is array (0 to did_width-1) of std_logic_vector (9 downto 0); --intiating inferred memory
signal did_arr : did_reg;
when DID_Y =>
checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0)) + unsigned(checksum_Y)); -- load check sum with previous checksum and current data value
for i in 0 to (did_width) loop -- Loop the did array
if i = did_width then -- If counter reaches the max amount of DID present+1 due to no DID match
curr_state_Y <= IDLE_Y; -- jump tp next state, IDLE_Y
elsif y_data = did_arr(i) then -- check if y_data matches with the element of the did array
mem_arr_Y(count_Y) <= y_data; -- if true, load the data to memeory
count_Y <= count_Y+1; -- increase the memory adress counter
curr_state_Y <= SDID_Y; -- jump to next state, SDID_Y
id_pair_cnt_Y <= i; -- ID pair adrs counter, for SDID pair adrs
exit; -- exit the loop when true
end if;
end loop;
type did_reg is array (0 to did_width-1) of std_logic_vector (9 downto 0); --instiating register based array of size equal to did width generic
type did_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
signal did_in : did_in_delay := (others => '0');
type y_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
signal y_data_delay : y_in_delay := (others => '0');
y_data <= DIN(19 downto 10);
when DID_Y =>
for i in did_width loop
did_in(i) <= y_data;
if did_in(i) = did_array(i) then
enable = '1';
else
enable = '0';
end if;
y_data_delay(i) <= y_data_delay(i)((y_data_delay(i)'high-1) downto 0)) & did_in(i)(i);
end loop;
entity generic_anc_extractor is
generic(
did_width : integer ;
sdid_width : integer
port(
output_data_at_vcount : in integer; --simulation specific feature. determines when to output the data.
-- x=0 -> output data at last vcount of frame- default value
-- 0<x -> output data at every vcount sel when hav = 1
VIDEO_CLK : in std_logic;
DATA_OUT_CLK : in std_logic;
RESET_N : in std_logic;
SOF : in std_logic;
HAV : in std_logic;
V_COUNT : in std_logic_vector(10 downto 0);
H_COUNT : in std_logic_vector(12 downto 0);
DIN_VALID : in std_logic;
DIN : in std_logic_vector(19 downto 0);
DIN_FORMAT : in std_logic_vector(3 downto 0);
DID_data : in std_logic_vector(9 downto 0);
SDID_data : in std_logic_vector(9 downto 0);
D_WR : in std_logic;
D_ADRS : in std_logic_vector(log2c(did_width)-1 downto 0);
SD_WR : in std_logic;
SD_ADRS : in std_logic_vector(log2c(sdid_width)-1 downto 0);
DOUT_OUT : out std_logic_vector(19 downto 0);
DATA_VALID_Y : out std_logic;
DATA_VALID_C : out std_logic
end generic_anc_extractor;
architecture rtl of generic_anc_extractor is
constant C_ADF1 : std_logic_vector(9 downto 0 ) := "0000000000"; -- 0
constant C_ADF2 : std_logic_vector(9 downto 0 ) := "1111111111"; -- 3FF
constant C_ADF3 : std_logic_vector(9 downto 0 ) := "1111111111"; -- 3FF
constant main_mem_N_Y : integer := 10000; -- Width of the main memory, equal to max anc data to be stored
constant main_mem_N_C : integer := 10000; -- Width of the main memory, equal to max anc data to be stored
-- constant did_width : integer := 5;
-- constant sdid_width : integer := 5;
type state_extrac_y is (IDLE_Y,
ADF_2_Y,
ADF_3_Y,
DID_Y,
SDID_Y,
DC_Y,
UDW_Y,
CS_Y
type state_extrac_c is (IDLE_C,
ADF_2_C,
ADF_3_C,
DID_C,
SDID_C,
DC_C,
UDW_C,
CS_C
signal curr_state_Y : state_extrac_Y_1;
signal curr_state_C : state_extrac_C;
signal dc_count_Y : integer := 0;
signal dc_count_C : integer := 0;
signal reg_out_Y : std_logic_vector(9 downto 0);
signal reg_out_C : std_logic_vector(9 downto 0);
signal data_count_Y : integer := 0; -- count is equal to DC_Y, representing the amount of UDW_Y data
signal checksum_Y : std_logic_vector(8 downto 0); -- checksum is equal to the sum of DID_Y to UDW_Y, which is then checked against CS_Y 9 bits value
signal count_Y : integer := 0; -- count for adress of the register memory
signal cnt_Y : integer := 0; -- count for writing extracted data to output port
signal data_count_C : integer := 0; -- count is equal to DC_C, representing the amount of UDW_C data
signal checksum_C : std_logic_vector(8 downto 0); -- checksum is equal to the sum of DID_C to UDW_C, which is then checked against CS_C 9 bits value
signal count_C : integer := 0; -- count for adress of the register memory
signal cnt_C : integer := 0; -- count for writing extracted data to output port
signal did_cnt : integer := 0; -- DID counter
signal sdid_cnt : integer := 0; -- SDID counter
signal id_pair_cnt_Y : integer := 0; -- Counter for the pair index for DID and SDID
signal id_pair_cnt_C : integer := 0;
signal last_vcount_f2 : integer := 0; -- returns the last value of vcount of every format of frame 2
signal last_vcount_f1 : integer := 0; -- returns the last value of vcount of every format of frmae 1
signal y_data : std_logic_vector(9 downto 0); -- upper 10 bits of the video stream(20-11 / 20)
signal c_data : std_logic_vector(9 downto 0); -- lower 10 bits of the video stream(10-0 / 20)
signal DATA_VALID_Y_d : std_logic := '0';
signal DATA_VALID_C_d : std_logic := '0';
type main_mem_reg_Y is array (0 to main_mem_N_Y-1) of std_logic_vector (9 downto 0); --instiating register based main memory of max size of anc data that can be stored
signal mem_arr_Y : main_mem_reg_Y;
type main_mem_reg_C is array (0 to main_mem_N_C-1) of std_logic_vector (9 downto 0); --instiating register based main memory of max size of anc data that can be stored
signal mem_arr_C : main_mem_reg_C;
type sdid_reg is array (0 to sdid_width-1) of std_logic_vector (9 downto 0); --instiating register based array of size equal to sdid width
signal sdid_arr : sdid_reg;
-- type did_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
-- signal did_delay : did_in_delay ;
-- type y_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
-- signal y_delay : y_in_delay;
-- signal did_match : std_logic;
-- signal c : std_logic_vector(8 downto 0);
-- signal shreg_did : std_logic_vector(9 downto 0);
-- signal shreg_y : std_logic_vector(9 downto 0);
begin
-------------------------------------------------------------------------------------Generate output data signal for extracted data from y and c data
process(DATA_OUT_CLK)
begin
if rising_edge(DATA_OUT_CLK) then -- Output of the data on the rising edge of clk given by the outer interface
if unsigned(H_COUNT) >= 4096 then -- check for hcount 0, start of active video
DOUT_OUT <= reg_out_Y®_out_C; -- output the extracted the data from y and c data
DATA_VALID_Y <= DATA_VALID_Y_d;
DATA_VALID_C <= DATA_VALID_C_d;
end if;
end if;
end process;
---------------------------------------------------------------------------------------------Loading DID_Y/SDID_Y serially to the array
process(VIDEO_CLK)
begin
if rising_edge(VIDEO_CLK) then
if D_WR = '1' then -- check for did write enable signal
did_cnt <= to_integer(unsigned(D_ADRS)); -- loading the did adrs to did_cnt signal
did_arr(did_cnt) <= DID_data; -- load the did in to did array according to the adress signal
end if;
if SD_WR = '1' then -- check for did write enable signal
sdid_cnt <= to_integer(unsigned(SD_ADRS)); -- loading the sid adrs to sdid_cnt signal
sdid_arr(sdid_cnt) <= SDID_data; -- load the did in to did array according to the adress signal
end if;
end if;
end process;
------------------------------------------------------------------------------------Current State Logic
--Generate reset and next state signals
--at every clock, update the curr_state value
--when reset,curr_state is IDLE_Y
generate_state: process(VIDEO_CLK)
begin
y_data <= DIN(19 downto 10); -- loading the upper 10 bits
if RESET_N = '0' then
curr_state_Y <= IDLE_Y; -- default state
else
if DIN_VALID = '1' then -- check for data valid signal
case curr_state_Y_1 is
------ -------------------------------------------------------------------------------------------------------------IDLE_Y
when IDLE_Y =>
checksum_Y <= (others=>'0'); -- Reset checksum value for next anc data packet
DATA_VALID_Y_d <= '0';
last_vcount_f1 <= return_vcount_active_end_f1(DIN_FORMAT); -- last vcount of frame according to the Video Format
last_vcount_f2 <= return_vcount_active_end_f2(DIN_FORMAT);
if y_data = C_ADF1 then -- check for ADF_1 - 0
curr_state_Y <= ADF_2_Y; -- jump to next state when true
else
curr_state_Y <= IDLE_Y; -- Jump to IDLE_Y when false
end if;
--OUTPUTTING THE EXTRACTED DATA FROM THE MEMORY
if output_data_at_vcount = 0 and cnt_Y< count_Y and HAV = '1' and (unsigned(V_COUNT) = last_vcount_f1 or unsigned(V_COUNT) = last_vcount_f2) then -- check for last count according to frame 1 and 2; simulation specification -> FPGA implementation, check for space in memory and active video
reg_out_Y <= mem_arr_Y(cnt_Y); -- output data of register buffer starting from adrs 0 to the data stored in one line
cnt_Y <= cnt_Y+1; -- increase the adrs cnt till all the data is read from the register
DATA_VALID_Y_d <= '1'; -- Trigger signal to indicate data valid when the data is being output
elsif output_data_at_vcount >= 1 and unsigned(V_COUNT) > 0 and cnt_Y< count_Y and HAV = '1' then-- simulation specification -> Simulation implementation,-- output only after vcount 0, check for space in memory and active video
end if;
-----------------------------------------------------------------------------------------------------------------ADF_2_Y / ANC DATA FLAG
when ADF_2_Y => -- ADF_2_Y - 3FF
if y_data = C_ADF2 then -- check for ADF_2_Y - 3FF
curr_state_Y <= ADF_3_Y; -- jump to next state when true,ADF_3_Y
else
end if;
-----------------------------------------------------------------------------------------------------------------ADF_3_Y / ANC DATA FLAG
when ADF_3_Y => -- ADF_3_Y
if y_data = C_ADF3 then -- check for ADF_3_Y - 3FF
curr_state_Y <= DID_Y; -- jump to next state when true, DID_Y
else
end if;
when DID_Y =>
checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0)+checksum_Y)); -- load check sum with previous checksum and current data value
elsif i = did_width then -- If counter reaches the max amount of DID present+1 due to no DID match
end if;
end loop;
------ -----------------------------------------------------------------------------------------------------------------SDID_Y/ SECONDARY DATA ID
when SDID_Y =>
checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0))+unsigned(checksum_Y));-- load check sum with previous checksum_C and current data value
if y_data = sdid_arr(id_pair_cnt_Y then -- SDID array of adress of id pair cnt equal to y data
mem_arr_Y(count_Y) <= y_data; -- if true, then load the data to the memory
curr_state_Y <= DC_Y; -- jump to next state, DC_Y
else
curr_state_Y <= IDLE_Y; -- if false, jump to default state, IDLE_Y
count_Y <= count_Y-1; -- decrease the memory adres counter, to over write the data alerady written
end if;
-----------------------------------------------------------------------------------------------------------------DC_C/ DATA COUNT
when DC_Y =>
dc_count_Y <= to_integer(unsigned(y_data(8 downto 0))); -- first 9 bits of the c_data, is equal to the no. of UDW_C in the packet
checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0))+unsigned(checksum_Y)); -- load check sum with previous checksum_C and current data value
mem_arr_Y(count_Y) <= y_data; -- store data in memory
count_Y <= count_Y +1; -- increase the memeory adress counter
curr_state_Y <= UDW_Y; --jump to next state, UDW_C
-----------------------------------------------------------------------------------------------------------------UDW_C/ USER DATA WORDS
when UDW_Y =>
if data_count_Y <= dc_count_Y then -- loops the process checking if data_count_C is less than/equal to dc_count(no of UDW_C)
checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0))+unsigned(checksum_Y)); -- load check sum with previous checksum_C and current data value when true
data_count_Y <= data_count_Y+1; -- data count value determines the amount of packet loaded in the memory
count_Y <= count_Y+1; -- incraese the memory adress counter
if data_count_Y = dc_count_Y-1 then -- when count is equal to the no. of UDW_C. dc_count-1, because we start counting from 0
data_count_Y <= 0; -- reset count to 0, will count next from next data UDW_C
curr_state_Y <= CS_Y; -- jump to next state, CS_C when all the UDW_C is loaded
end if;
end if;
-- -----------------------------------------------------------------------------------------------------------------CS_C/CHECKSUM
when CS_Y =>
if checksum_Y = y_data(8 downto 0) then -- checks the data with the checksum_C value
curr_state_Y <= IDLE_Y; -- jump to next state, IDLE_C when true
count_Y <= count_Y +1; -- incraese the memory adress counter
else
curr_state_Y <= IDLE_Y; -- jump to default IDLE_C, when false
count_Y <= count_Y - dc_count_Y-3; -- wrap around the adres of the register back to where it stored the 1st data of the pckt
end if; -- will overwrite the new data over the present adres
when others => curr_state_Y <= IDLE_Y; -- default case
end case;
end if; -- dvalid
end if; -- reset
end if; -- VIDEO_CLK
end process;
end process;
-> It doesn´t matter if it takes even 40 clock cycles to do the whole thing
I just can't use a counter for it.
Reason: The input is a serial data of 10 bits each. So, I can't pause the data. And we do not want to use a buffer type system. But something more of using shifter or small array based system.
