syedahmar
Member level 1
Hello all!!!
i have designed a transmitter and the output of this transmitter is one pin..Now the requirement is that the transmission be done on differential lines and that means that i have to assign my output pin to LVDS standard and that has two output pins...
The problem is that i go to the constraint editor and i make my pin IO standard as LVDS_25 but in the pad report it assigns only one of the two pins and the IO standard it shows is LVCMOS.......
the device i am using is spartan 3 and the software is xilinx ISE..\
help plz....
help plz....
