pid controller vhdl code
mansi0905
Junior Member level 1
jaipur
i have to design a pid controller for controlling the duty cycle. the problem is wrote a vhdl code but they simulation results show undefind output of pid evry alternate clock cycle. i am not able to underdstand the problem.
pls help.
permute
Advanced Member level 3
check for multiple drivers, or check the inputs to the assignment of the affected signal.
    V
mansi0905
jaipur
i have already checked the code . i don't think dat there is prblm of multiple drivers. here is d code.
pls lemme know the error in dis vhdl code .
entity pid is
port(
u_out:eek:ut std_logic_vector( 15 downto 0);
e_in:in std_logic_vector(15 downto 0);
clk:in std_logic;
reset:in std_logic);
end pid;
architecture Behavioral of pid is
signal u1: std_logic_vector(15 downto 0);
signal u_prev : std_logic_vector( 15 downto 0);
signal e_prev1: std_logic_vector( 15 downto 0);
signal e_prev2: std_logic_vector( 15 downto 0);
constant k1: std_logic_vector( 6 downto 0 ):="1101011";
constant k2:std_logic_vector( 6 downto 0):="1101000";
constant k3: std_logic_vector( 6 downto 0) :="0000010";
begin
process( clk)
begin
if( clk'event and clk='1') then
if reset ='1' then
u_prev <="0000000000000000";
e_prev1<="0000000000000000";
e_prev2<="0000000000000000";
else
e_prev2<=e_prev1;
e_prev1<=e_in;
u_prev<=u1;
u1<= u_prev + (k1*e_in)+(k2*e_prev2)+(k3*e_prev2);
end if;
end if;
u_out<=u1;
end process;
end Behavioral;
Reactions: EngHussein
    V
    EngHussein
permute
there are several things that can be done better. Here are my suggestions:
1.) u1 needs some action on the reset. this is your issue.
2.) really, it doens't need a reset at all. it could be moved out of the if-reset block.
3.) e_prev2 appears for k2 and k3. this is probably a mistake.
this does have a long longest path, so if a high clock rate is needed, you might need to do something to improve performance.
Added after 45 seconds:
also, none of the multiplies will be correct. the output of a*b is a vector of length len(a)+len(b).
vipinlal
Full Member level 6
India
In the above code the following statements are blocking statements:
--first three statements happens in the first clock cycle.
e_prev2<=e_prev1;
e_prev1<=e_in;
u_prev<=u1;
--this statment happens in the 2nd clock cycle.So output comes every 2 clock cycle.
Use variables inside the process.Then it will work.
--vipin
https://vhdlguru.blogspot.com/
vipinlal
Full Member level 6
India
@Tricky : Why it will not work?
The statement is similar to this right.
u1<= u1 + (k1*e_in)+(k2*e_prev2)+(k3*e_prev2);
What do you mean by it is never given a value.Can you explain more?
mansi0905
jaipur
thanks a lot for d suggestion .
i have replaced e_prev2 e_prev1 . yes it was an error but then also it was still giving same result .
then i tried using variable inside process then the output of pid was undefined for all the clock cycles.
pls help
mansi0905
jaipur
here is the new code for pid
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity pid is
port(
clk:in std_logic;
end pid;
begin
process( clk)
--variable u1: std_logic_vector(15 downto 0);
--variable u_prev : std_logic_vector( 15 downto 0);
--variable e_prev1: std_logic_vector( 15 downto 0);
--variable e_prev2: std_logic_vector( 15 downto 0);
--constant k1: std_logic_vector( 6 downto 0 ):="1101011";
--constant k2:std_logic_vector( 6 downto 0):="1101000";
--constant k3: std_logic_vector( 6 downto 0) :="0000010";
begin
if reset ='1' then
else
e_prev2<=e_prev1;
e_prev1<=e_in;
u_prev<=u1;
u1<= u_prev + (k1*e_in)+(k2*e_prev1)+(k3*e_prev2);
end if;
end if;
u_out<=u1;
end process;
end Behavioral;
vipinlal
Full Member level 6
India
Can you try out this code and tell me what is the output?
library IEEE;
entity pid is
port(
u_out:out std_logic_vector( 15 downto 0);
clk:in std_logic;
end pid;
begin
process( clk)
begin
if reset ='1' then
u_prev :="0000000000000000";
e_prev1:="0000000000000000";
e_prev2:="0000000000000000";
else
e_prev2:=e_prev1;
e_prev1:=e_in;
u1:= u1 + (k1*e_in)+(k2*e_prev1)+(k3*e_prev2);
end if;
end if;
u_out<=u1;
end process;
end Behavioral;
--vipin
mansi0905
jaipur
i tried this code but simulation results show u_out as undefined for all the clock cycles. thanks a lot for help
permute
"1.) u1 needs some action on the reset. this is your issue."
"No It wont.
U1 is never given a value."
u1 starts at xxxx. thus, on the first cycle, you will have: xxxx + 0000 + 0000 + 0000 = xxxx. the next cycle, xxxx + ...
I suggest that variables never be used to infer registers. its not that they can't, it's that it is more difficult to read/modify/write the code correctly.
vipinlal
Full Member level 6
India
So does this solve the problem while initializing u1?
variable u1: std_logic_vector(15 downto 0):=(others => '0');
mansi0905
jaipur
sorry i am not getting what should be done . could you please explain a bit more about the suggestion
kesava
Newbie level 1
i has simulated this code but i am not getting how to check the output
