PID controller for the heater
nileshthakare2
Member level 1
I have plant value and set point value and for the PID processing i made the code
void pid_correct(unsigned int plant_value)
unsigned int SET_POINT,integral,prev_error;
//the plant error
//make sure error is positive when you need to apply a larger pwm value (wider positive width)
unsigned int error = plant_value - SET_POINT;
//int16_t error = ((int16_t) SET_POINT) - plant_value;
//proportional * pGain
unsigned int proportional = error * 200;
//integral * iGain
unsigned int temp_sum = integral + ( error * 10 );
//check that the integral doesn't get out of the desired range
if ( temp_sum > 0xFFFF ) integral = 0xFFFF;
else
if (temp_sum < (-0xFFFF) ) integral = -0xFFFF;
else
integral = temp_sum;
//differential * dGain
//if you used the other error calculation, use the other differential as well
unsigned int differential = ( (error - prev_error) * 20 );
//int32_t differential = ( (prev_error - error) * 20 );
//the final sum, with an overflow check
unsigned int temp_pid_sum = proportional + integral + differential;
unsigned int pid_total;
//set max pwm value at ~95% of 2^16 (change this to whatever you like)
if ( temp_pid_sum > 62258 ) pid_total = 62258;
else
if ( temp_pid_sum < 0 ) pid_total = 0;
else
pid_total = (unsigned int) temp_pid_sum;
//set pwm compare value to change the duty cycle
OCR1A = pid_total;
//store the previous error
prev_error = error;
This is taken from the example code. In this code the OCR1A control the pwm of the controller .my question is
how OCR1A = pid_total;control the pwm because pid_total is the difference between set point and plant value.Also how we interface the code with main due to that continue sly get correct output
