[PIC] Picstart 16B1 software needed
edugo
Newbie level 1
Newbie level 1
Hi!... Will anyone have a copy of the old programs used by picstart 16B?
I'm in Venezuela and around here somepeople still use that equipment...
pjmelect
Advanced Member level 2
Unfortunately Microchip no longer has the software on their web site, I have MPLAB 5.4 and 5.7 which I could email to you if you PM me. The files are 13MB or so each if your email provider allows this.
FvM
Super Moderator
Staff member
Advanced Member level 7
Bochum, Germany
Old MPLAB versions like 5.4 and 5.7 can be downloaded from Microchip https://www.microchip.com/development-tools/pic-and-dspic-downloads-archive
I'm not sure which software is exactly required to sure to run PICSTART, respectively what the latest MPLAB version supporting it. Said 5.4 and 5.7 won't run an modern Windows versions, you'll probably use a virtual machine.
pjmelect
These versions of MPLAB were designed to run on Windows 98, however on Windows XP you get read errors from the devices to be programmed which you can correct by deleting a running process with task manager, unfortunately I can't remember which process you had to stop. Does anyone know? I would be interested to know.
