PICKIT2 Universal ZIF Socket FINAL
Fragrance
East Of Earth
Hi
here is universal ZIF socket for pickit2 full release adding more pic ad improving hardware
Feature
input is truly compatible with pickit2 programmer can be used with other programmer as well supported devices are as under, also do not forget to solder the SMD resistor
16F = 40,28,20,18,14
18F = 40,28,20,18
12F
10F
Regards
Fragrance
  • PPICKIT2 UIVERSAL ZIF FINAL.pdf
Re: Universal ZIF socket for PICKIT2
so final version shared supported all pic from 8 pin to 40 pin including 10F
regards
Fragrance
Good job done, thanks. Hope. it will work on pins from 8 to 40 as you have stated. I will make one, test and will use in my programmer.
before sharing yes i have carefully tested it, further i study the data sheet for different PIC to draw the proper wiring connection to pic also do not forget to solder the three SMD resistor
regards
Fragrance
good job fragrance, but is is possible to use normal resistor if one cannot get the surface mount?
yes you can used other type resistor, here you can used 1/8 watt resistor instead of SMD
regards
Fragrance
hi fragrance please can u post the ares file (board layout) itself as it was very big when i printed the pdf on printer. thanks
OK here you go
regards
Fragrance
  • PICKIT2 UIVERSAL ZIF FINAL.7z
thanks frag, i will check out and mke my board. please before i go n permit me to modify it at will..
thanks.
thanks.
if it is only for hobby purpose then go for it, if for commercial use then not
regards
Fragrance
Does it also designed for dsPIC series ?
