No the circuit needn't be modified. I am refering to the PiCkit2 Lite circuit from "blueroom" which can be found on EDA board. Just have a search. If you coudnt find, i'll specify a link in my next post. Directly use transistors in place. But the Base-Emitter-Collector pins are just opposite to the one we have on general purpose makes like the BC548. just refer the datasheet.hi pranam77, iam using 680uhy. iam very interested in the use of the transistors. so, you used 3 npn and 1 pnp. did you have to modify the circuit in any way? btw, after much searching i finally found a source for IRLML6402. its called Dipmicro located in Canada.
Dear all,
Sorry for commenting in an old thread.
I fond the schematic of the blueroom electronics pickit2 but need the hex file for the 18f2550. Can one of you please upload it here.
BTW can you program all the pic microcontrollers that are programmable by the original pickit2 (10F, 12F, 16F, 18F, 24F, dsPIC30F & dsPIC33F)?
Best regards
Dear wp100,
Thank you for your fast reply. Another simple question, in your layout there are 3 leds but the schematic that you uploaded (which is as same as mine) has only 2 leds. Can you please tell me whet is the 3rd leds purpose and where it connects to?
Regards
