omid_juve
Full Member level 1
12c508a picbasic pro
Hi
I wrote a simple basic program for my PIC (12c508A) in a Picbasic Pro compiler
but I have this error after compilation "unable to fit variable soft_stack"
please see my program below and tell me the errors as I am beginner in PIC programming .
Thanks
lowinput VAR GPIO.0
overtemprature VAR GPIO.1
overload VAR GPIO.2
outputpin VAR GPIO.3
green VAR GPIO.4
red VAR GPIO.5
count1 var byte
i var byte
OUTPUT outputpin
input lowinput
input overtemprature
input overload
OUTPUT green
OUTPUT red
while i=0
if (lowinput=0) and (overload=0) and (overtemprature=0) then
outputpin =0
High green
Pause 500
Low green
Pause 500
ENDIF
if (lowinput=0) and (overload=1) and (overtemprature=0) then
while count1<2
gosub overloadmode
count1=count1+1
wend
outputpin =1
while count1<7
gosub overloadmode
count1=count1+1
wend
outputpin =0
count1=0
ENDIF
if (lowinput=1) and (overload=0) and (overtemprature=0) then
while count1<5
gosub lowinputmode
count1=count1+1
wend
outputpin =1
count1=0
ENDIF
if (lowinput=0) and (overload=0) and (overtemprature=1) then
while count1<5
gosub overtempraturemode
count1=count1+1
wend
outputpin =1
count1=0
ENDIF
if (lowinput=1) and (overload=1) and (overtemprature=0) then
while count1<5
count1=count1+1
wend
outputpin =1
count1=0
endif
wend
overloadmode:
High green
low red
Pause 500
Low green
high red
Pause 500
return
lowinputmode:
High green
low red
Pause 500
Low green
high red
Pause 500
return
overtempraturemode:
High green
high red
Pause 500
Low green
low red
Pause 500
return
end
Hi
Thanks
lowinput VAR GPIO.0
overload VAR GPIO.2
green VAR GPIO.4
red VAR GPIO.5
count1 var byte
i var byte
OUTPUT outputpin
input lowinput
input overload
OUTPUT green
OUTPUT red
while i=0
outputpin =0
High green
Pause 500
Low green
Pause 500
ENDIF
while count1<2
gosub overloadmode
count1=count1+1
wend
outputpin =1
while count1<7
gosub overloadmode
count1=count1+1
wend
outputpin =0
count1=0
ENDIF
while count1<5
gosub lowinputmode
count1=count1+1
wend
outputpin =1
count1=0
ENDIF
while count1<5
count1=count1+1
wend
outputpin =1
count1=0
ENDIF
while count1<5
count1=count1+1
wend
outputpin =1
count1=0
endif
wend
overloadmode:
High green
low red
Pause 500
Low green
high red
Pause 500
return
lowinputmode:
High green
low red
Pause 500
Low green
high red
Pause 500
return
overtempraturemode:
High green
high red
Pause 500
Low green
low red
Pause 500
return
end
