PicBasic Pro and Graphics LCD
aghazi
Junior Member level 2
lcd picbasic
I know how to use Hitachi 44780 based character lcd with PIC using Picbasic pro. Can anyone please guide me how to use Graphics LCD instead? I want to use it with PIC16F877A and picbasic pro.
Really appreciate your help. Thanks.
AG
picbasic glcd
i am also interest
pic basic lcd
Hi, All,
GLCD can work with any PIC. however it requires considerably more I/O lines. PROTON BASIC supports GLCD on PIC16 Family.
picbasic pro glcd
So it means that we can not use graphic lcd in picbasic pro? Hard to believe.
picbasic graphic lcd
i am also very very interest but i think GLCD works with PIC18 only
this link for mikrobasic
https://www.mikroe.com/en/books/picbasicbook/07.htm
All Mikroe PIC based boards support PIC16 chips with GLCD, and there installation disks include examples for 16F877 and GLCD. Full support is provided through their proprietory languages as well.
The Oshon sim also provides GLCD support from BASIC, including simulation of the GLCD on the PC, see www.oshonsoft.com for a fully working evaluation.
proton basic glcd
well mr agazhi ,
graphic lcd also runs on 8-bit data , so it is 100% interfaceable with pic16 series.
as far as coding is concerned mailme back . i have successfully interfaced it with all the text and rectangles etc .
its very simple , all you have to do is write functions for:
command write
data write
rectangle coordinates
line draw etc...
prefer to make your own functions instead of using inbuilt libraries
sample code in basic rough idea , remember all the code might not be right according to you , but it works according to the application i had , i am reading code for characters 5X7 through 5 lookups i.e 5 columns:
define osc 20
trisc = $00
trisd = $00
en var portd.0
rw var portd.1
rs var portd.2
cs1 var portd.3
cs2 var portd.4
reset var portd.5
temp1 var byte
temp2 var byte
c1 var byte
temp var byte
xemp var byte
m var byte
x_pos1 var byte
x_pos2 var byte
up_page var byte
down_page var byte
upper_line var byte
lower_line var byte
B1 var byte
y_pos1 var byte
y_pos2 var byte
x var byte
y var byte
a var byte
b var byte
c var byte
d var byte
e var byte
i var byte
b0 var byte
rs = 1
rw = 0
en = 0
x = 0
y = 0
cs1 = 1
cs2 = 1
xemp = $00
'x_pos1 = 8
'x_pos2 = 63
'y_pos1 = 2
'y_pos2 = 60
'temp1 = x_pos1
'temp2 = x_pos2
'up_page = x_pos1 / 8
'down_page = x_pos2 / 8
'upper_line = temp1 // 8
'lower_line = temp2 // 8
type var byte
reset = 0
pause 1000
reset = 1
temp = $3e
gosub command_write
pause 100
temp = $3f
gosub command_write
pause 100
clear_display: 'clrscr
for x = 0 to 7
temp = $b8 + x
gosub command_write
for y = 0 to 63 'column increase automatic on every write
temp = $00
gosub data_write
next y
next x
pause 1000
cs2 = 0
gosub starting_address
goto alpha_change
column_change: if (y < 125 ) then
temp = $40 + y
endif
gosub command_write
page_change: if (x <= 7) then
temp = $b8 + x
else
x = 0
temp = $b8 + x
endif
gosub command_write
alpha_change:
LOOKUP b0,["the easiest way to earn money is smugglingbut
that is dangerous!"],c1
type = c1
if (type != 33 ) then
i = type - 32
else
goto l
endif
gosub display_0
gosub data_write
y = y + 1
gosub test_mid
gosub test_last
pause 10
gosub display_1
gosub data_write
y = y + 1
gosub test_mid
gosub test_last
pause 10
gosub display_2
gosub data_write
y = y + 1
gosub test_mid
gosub test_last
pause 10
gosub display_3
gosub data_write
y = y + 1
gosub test_mid
gosub test_last
pause 10
gosub display_4
gosub data_write
y = y + 1
gosub test_mid
gosub test_last
pause 10
temp = $00
gosub data_write
y = y + 1
gosub test_mid
gosub test_last
pause 10
b0 = b0 + 1
pause 2
goto column_change
goto l
'------------------------------sub-routines-------------------------------------
test_mid: if (y == 64) then
cs1 = 0
cs2 = 1
temp = $b8 + x
gosub command_write
temp = $40
gosub command_write
pause 5
endif
return
test_last: if (y == 126) then
cs1 = 1
cs2 = 0
x = x + 1
temp = $b8 + x
gosub command_write
temp = $40
gosub command_write
y = 0
endif
return
starting_address:
b0 = 0
y = 0
x = 0
temp = $c0
gosub command_write
temp = $b8 + x
gosub command_write
temp = $40 + y
gosub command_write
return
space: temp = $00
gosub data_write
return
data_write: rw = 0
rs = 1
portc = temp
en = 1
pause 5
en = 0
return
command_write: rw = 0
rs = 0
portc = temp
en = 1
pause 5
en = 0
return
display_0:
if (i <= 64 ) then ' ! " # $ % & '
( ) * + , - . / 0 1 2 3 4
5 6 7 8 9 : ; < = > ? @
A B C D E F G H I J K L M N O
P Q R S T U V W X Y Z [ \
] ^ _ `
LOOKUP2 i , [$00, $00, $00, $14, $24, $23, $36,
$00, $1c, $00 ,$14, $08, $00, $08, $00, $20, $3E, $00, $42, $21,
$18, $27, $3C, $01, $36, $06 , $00, $00, $08, $14, $00, $02 ,
$32, $7e, $7f, $3e, $7f, $7f, $7f, $3e, $7f, $00, $20 ,$7f, $7f, $7f,
$7f, $3e, $7f , $3e, $7f, $46, $01, $3f, $1f , $3f, $63 ,$07, $61 ,
$7f ,$02, $00 ,$04 ,$40 ,$00 ],B1
portc = B1
temp = portc
RETURN
else
i = i - 65 ' a b c d e f g h
i j k l m n o p q r s t u v
w x y z { | } ~
LOOKUP2 i , [$20, $7f, $38, $38, $38, $08, $08,
$7f, $00, $00 ,$7f, $00, $7c, $7c, $38, $7c , $08, $7c, $48, $04, $3c,
$1c , $3c, $44 ,$0c, $44, $08 ,$00 ,$00 ,$00 ],B1
portc = B1
temp = portc
i = i + 65
RETURN
endif
display_1:
' ( ) * + , - . / 0 1 2 3
4 5 6 7 8 9 : ; < = > ? @
] ^ _ `
LOOKUP2 i , [ $00, $00, $07, $7f, $2a, $13, $49,
$05, $22, $00 ,$08, $08, $50, $08, $60, $10, $51, $42, $61,
$41, $14, $45, $4A, $71, $49, $49 , $36, $56, $14, $14, $41, $01 ,
$49, $11, $49, $41, $41, $49, $09, $41, $08, $41, $40 ,$08, $40,
$02, $04, $41, $09, $41, $09, $49, $01 , $40, $20, $40, $14 , $08, $51 ,
$41 ,$04, $00, $02, $40, $14 ],B1
portc = B1
temp = portc
RETURN
else
h i j k l m n o p q r s t u
v w x y z { | } ~
LOOKUP2 i , [ $54, $48, $44, $44, $54, $7e, $54,
$08, $44, $20 ,$10, $41, $04, $08, $44, $14 , $14, $08, $54, $3f, $40,
$20 , $40, $28 ,$50, $64, $36 ,$00 ,$00 ,$08 ],B1
portc = B1
temp = portc
i = i + 65
RETURN
endif
display_2:
] ^ _ `
LOOKUP2 i , [$00, $4f, $00, $14, $7f, $08, $55,
$03, $41, $41 ,$3e, $3e, $30, $08, $60, $08, $49, $7f, $51,
$45, $12, $45, $49, $09, $49, $49 , $36, $36, $22, $14, $22, $51 ,
$79, $11, $49, $41, $41, $49, $09, $49, $08, $7f, $41 ,$14,
$40, $0c, $08, $41, $09, $51, $19, $49, $7f , $40, $40, $38, $08 , $70,
$49 , $41 ,$08, $41, $01, $40, $02 ],B1
portc = B1
temp = portc
RETURN
else
v w x y z { | } ~
LOOKUP2 i , [ $54, $44, $44, $44, $54, $09, $54,
$04, $7d, $40 ,$28, $7f, $18, $04, $44, $14 , $14, $04, $54, $44, $40,
$40 , $30, $10 ,$50, $54, $41 ,$7f ,$41 , $04 ],B1
portc = B1
temp = portc
i = i + 65
RETURN
endif
display_3:
2 3 4 5 6 7 8 9 : ; < = >
? @ A B C D E F G H I J
K L M N O P Q R S T U V W X
Y Z [ \ ] ^ _ `
LOOKUP2 i , [$00, $00, $07, $7f, $2a, $64, $22,
$00, $00, $22, $08 ,$08, $00, $08, $00, $04, $45, $40,
$49, $4b, $7f, $45, $49, $05, $49, $49 , $00, $00, $41, $14, $14,
$09 , $41, $11, $49, $41, $22, $49, $09, $49, $08, $41, $3f
,$22, $40, $02, $10, $41, $09, $21, $29, $49, $01 , $40, $20, $40, $14
, $08, $45 , $00 ,$10, $41, $02, $40, $04 ],B1
portc = B1
temp = portc
RETURN
else
v w x y z { | } ~
LOOKUP2 i , [$54, $44, $44, $48, $54, $01, $54,
$04, $40, $44 ,$44, $40, $04, $04, $44, $14 , $18, $04, $54, $40, $20,
$20 , $40, $28 ,$50, $4c, $00 ,$00 ,$36 , $08 ],B1
portc = B1
temp = portc
i = i + 65
RETURN
endif
display_4:
3 4 5 6 7 8 9 : ; < = > ?
@ A B C D E F G H I J K
L M N O P Q R S T U V W X Y Z
[ \ ] ^ _ `
LOOKUP2 i , [$00, $00, $00, $14, $12, $62, $50,
$00, $00, $1c ,$14, $08, $00, $08, $00, $02 , $3e, $00, $46,
$31, $10, $39, $30, $03, $36, $3e , $00, $00, $00, $14, $08, $06
, $3e , $7e, $36, $22, $1c, $41, $01, $7a, $7f, $00, $01
,$41, $40, $7f, $7f, $3e, $06, $5e, $46, $31, $01, $3f, $1f, $3f, $63,
$07, $43 , $00 ,$20, $7f, $04, $40, $00 ],B1
portc = B1
temp = portc
RETURN
else
v w x y z { | } ~
LOOKUP2 i , [ $78, $38, $20, $7f, $18, $02, $3c,
$78, $00, $3d ,$00, $00, $78, $78, $38, $08 , $7c, $08, $20, $20, $7c,
$1c , $3c, $44 ,$3c, $44, $00 ,$00 ,$08 , $04 ],B1
portc = B1
temp = portc
i = i + 65
RETURN
endif
l: goto l
end
pic basic pro graphic lcd
All my programms i write with picbasic pro , but for GLCD i use Proton.
graphic lcd pic basic
i use picbasic pro,what should i do?
lcd connected to pic with picbasic pro
any answer?
connected lcd in to pic with picbasic pro
Any answer?
