int main()
NVMUnlock (0x0000C001);
Buffer[0]=0xBF80F400;
NVMErasePage(Buffer);
NVMWriteWord(Buffer,0x06);
NVMReadWord(Buffer);
unsigned int NVMUnlock (unsigned int nvmop)
unsigned int status;
asm volatile ("di %0" : "=r" (status));
// Enable Flash Write/Erase Operations and Select
// Flash operation to perform
NVMCON = nvmop;
// Write Keys
NVMKEY = 0xAA996655;
NVMKEY = 0x556699AA;
// Start the operation using the Set Register
NVMCONSET = 0x8000;
// Wait for operation to complete
while (NVMCON & 0x8000);
// Restore Interrupts
if (status & 0x00000001)
asm volatile ("ei");
else
asm volatile ("di");
// Return NVMERR and LVDERR Error Status Bits
return (NVMCON & 0x3000);
unsigned int NVMErasePage(void* address)
unsigned int res;
// Set NVMADDR to the Start Address of page to erase
NVMADDR = (unsigned int) address;
// Unlock and Erase Page
res = NVMUnlock(0x4004);
// Return Result
return res;
unsigned int NVMWriteWord (void* address, unsigned int data)
unsigned int res;
// Load data into NVMDATA register
NVMDATA = data;
// Load address to program into NVMADDR register
// Unlock and Write Word
res = NVMUnlock (0x4001);
// Return Result
return res;
unsigned int NVMReadWord (void* address)
unsigned int res;
res=NVMADDR;
// Return Result
return res;
