it`s so great... i`am still trying to user lcd n6100 with my atmega 32...... would you want to share PCB for th N6100 LCD...? it`s have very small connector...
Quite nice. How fast is SPI bus in this project. Image loading is visible. Can it be improved? Will you share the source code? Is it just an evaluation board or a part of some bigger project?
PCF8833 will not respond at higher SPI rates. I am using software SPI.
its a home made PCB. I made that to familiarize USB host feature of PIC32 + with some standard communication points and connections + grouped ports + ZigBee slot etc.
Program Hint:
Microchip USB host Stack + 6100 LCD Driver + Jpeg/your own decoding technique (Uncompressed image formats are recommended to increase decoding speed)
I having sony ericson 550i mobile, the display of that device i want to use for my project but i didnt find any datasheet of that.
where did you get the details of your lcd? If you know the source where i can find the datasheet of display that i want to use please share it.
Thanks
