PIC24FJ128GA010 Clock settings
Kareem101
Newbie level 2
The Data sheet says that this chip can do 16 MIPS @32Mhz, although I cant make it work @ 32Mhz
From MPLABX V2.26 and using C30, I generated these Config bits Value as follow :
Code C - [expand]
8
9
int CONFIG2 __attribute__((space(prog), address(0x157FC))) = 0xFB3E ;
//_CONFIG2(
//    POSCMOD_HS &         // Primary Oscillator Select (HS Oscillator mode selected)
//    OSCIOFNC_OFF &       // Primary Oscillator Output Function (OSC2/CLKO/RC15 functions as CLKO (FOSC/2))
//    FCKSM_CSECME &       // Clock Switching and Monitor (Clock switching is enabled, Fail-Safe Clock Monitor is enabled)
//    FNOSC_PRIPLL &       // Oscillator Select (Primary Oscillator with PLL module (HSPLL, ECPLL))
//    IESO_ON              // Internal External Switch Over Mode (IESO mode (Two-Speed Start-up) enabled)
Now I know that my controller is not working @ 32Mhz as I mesaured the clock on RC15 and found 8Mhz, Hence is working @16Mhz !
So my Question is , what I am missing ?? How to Make it work @ 32Mhz !!
That is not the way to set up the configuration bits. Look at the C30 User Guide, section 6.6.1.
Also read Section 8 of the data sheet and the Family Reference Manual Section 6 which explain the oscillator setup.
What is frequency of the crystal you are using? I assume it is 8MHz since you are measuring RC15 and this pin is acting as the OSCO line to drive the crystal. (It is NOT Fosc/2 in this configuration.)
If that is correct, then you actually need to use XT (and XTPLL) mode - look at Section 6.5 of the FRM to see the correct settings based on the crystal frequency.
I suggest that you have a look at some of the example code that is available from Microchip and also through a Google search to see how others have set up the oscillator. While the data sheets and FRM sections actually will tell you just about everything you will need to know to use these MCUs, there is a fairly steep learning curve involved, part of which is learning how to read these documents.
Susan
