PIC18F97J60 + MMC + WEB page
Virusasxx
Newbie level 3
Lithuania, Kaunas
Hello,
I got problem with "data.txt" showing in my WEB page from txt file, that is in MMC card.
I would like take data from txt file, and them show in web page :)
I don't now what to do ??? :( If somebody was doing something please help :)
Virusasxx
Newbie level 3
Lithuania, Kaunas
HI,
I got only PIC18F97J60 and I make t my own board :).
And in this board I need to get data from MMC card ant that data chow in web page ho is in PIC :)
And I don't know haw to do it :/
tpetar
Advanced Member level 5
Pancevo-Belgrade, Serbia
papunblg
Advanced Member level 3
Kolkata India
Papunblg see this web server with SD :
Xx virus can we get more detail about problem ?
tpetar that is very informative for this type of projects. Thank you.
---------- Post added at 17:00 ---------- Previous post was at 16:58 ----------
Virusasxx, it will help you
elt42at
Newbie level 6
You can use M.A.L. ( Microchip Application Libraries ) . After you install that, you can use TCP-IP stacks ( For example TCPIP\Demo App\C18-PICDN2_ETH97.mcp ) . In the M.A.L., there is "MDD File System-SD Card" project. It drives sd or mmc via SPI bus!
---------- Post added at 18:12 ---------- Previous post was at 18:06 ----------
at that link "" there is ENC28j60 ( external ethernet controller with phy via SPI port ) and atmega.
PIC18F97J60 is a microcontroller which includes ethernet controller and phy inside! So we only need an SD/MMC socket and card :D
I am suggesting that USE pic18f67j60. It is small and it has same FLASH and RAM size with 97j60. Easy to build PCB ;)
pasicr
Advanced Member level 1
Macedonia
Hi for VIRUSASXX,
do you fix your problem?
PHP:
Hello,
I have the same problem how, can you share with me your status now?
best regards
