#include "__NetEthInternal.h"
SOCKET_Intern_Dsc *clientSock;
// ipconfig /all
unsigned char myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f} ; // my MAC address
unsigned char myIpAddr[4] = {192, 168, 0, 123 } ; // my IP address
unsigned char gwIpAddr[4] = {192, 168, 0, 1 } ; // gateway (router) IP address
unsigned char ipMask[4] = {255, 255, 255, 0 } ; // network mask (for example : 255.255.255.0)
/// not sure, but ipconfig says so..
unsigned char dnsIpAddr[4] = {208, 67, 222, 222 } ; // DNS server IP address
unsigned char getRequest[15]; // HTTP request buffer
unsigned char dyna[31] ; // buffer for dynamic response
SOCKET_Intern_Dsc *socketHTML;
volatile int sentFlag = 0;
volatile int wantToSent = 0;
void Net_Ethernet_Intern_UserTCP(SOCKET_Intern_Dsc *socket) {
unsigned int len;
// I listen only to web request on port 80
// if(socket->destPort != 80) {
/// Net_Ethernet_Intern_putStringTCP("Hello", socket);
// return;
if(socket == clientSock && wantToSent == 1)
unsigned char sendline[64];
unsigned char host[32] = { "192.168.0.100" };
unsigned char page[32] = { "/test.php" };
unsigned char remoteIpAddr[4] = {0};
unsigned char sntpPkt[48] = {0};
unsigned char poststr[64] = { 0 };
wantToSent = 0;
sprintf(sendline,
"GET %s HTTP/1.0\r\n"
"\r\n", page);
Net_Ethernet_Intern_putStringTCP(sendline, socket);
// Net_Ethernet_Intern_disconnectTCP(socket);
sentFlag = 1;
return;
if(socket == clientSock && sentFlag == 1)
if (Net_Ethernet_Intern_bufferEmptyTCP(clientSock))
Net_Ethernet_Intern_disconnectTCP(clientSock) ;
clientSock = 0;
unsigned int Net_Ethernet_Intern_UserUDP(UDP_Intern_Dsc *udpDsc) {
return(0);
// Initialization of Timer1
unsigned int cnt;
void MCUInit() {
ADCON1 |= 0x0F; // Configure AN pins as digital
CMCON |= 7; // Disable comparators
cnt = 0; // Initialize cnt
TRISB = 0; // PORTB is output
PORTB = 0xFF; // Initialize PORTB
T0CON = 0xC4; // Set TMR0 in 8bit mode, assign prescaler to TMR0
INTCON = 0xC0; // Set GIE, PEIE
TMR0IE_bit = 1; // Enable TMRO interrupt
// Interrupt routine
void interrupt() {
if (TMR0IF_bit) {
cnt++; // Increment value of cnt on every interrupt
if (cnt >= 2500) {
PORTD = ~PORTD; // Toggle PORTB LEDs
cnt = 0; // Reset cnt
Net_Ethernet_Intern_UserTimerSec++;
TMR0L = 96;
TMR0IF_bit = 0; // clear TMR0IF
char i;
void test()
unsigned char remoteIpAddr[4] = {192,168,0,100};
Net_Ethernet_Intern_sendUDP( remoteIpAddr, 11000, 11000, "Hello from PIC18 Ethernet!", 48 );
Delay_ms(1);
void main() {
int port = 1100;
int cnt = 0;
ADCON1 = 0xff;
TRISA.F0 = 0; //Makes PORTA0 or RA0 Output Pin
TRISA.F1 = 0; //Makes PORTA1 or RA1 Output Pin
for(i = 0; i < 5; i++)
PORTA.F0 = 1; //LED ON
PORTA.F1 = 1; //LED ON
Delay_ms(200); //1 Second Delay
PORTA.F0 = 0; //LED OFF
PORTA.F1 = 0; //LED OFF
MCUInit();
// OSCTUNE = 0b01000000;
PORTD = 0;
TRISD = 0; // set PORTD as output,
PORTA = 0 ;
TRISA &= ~0b11 ; // RA0 and RA1 will be used as
// ethernet's LEDA and LEDB
Net_Ethernet_Intern_Init(myMacAddr, myIpAddr, Net_Ethernet_Intern_FULLDUPLEX) ; // init ethernet board
Net_Ethernet_Intern_confNetwork(ipMask, gwIpAddr, dnsIpAddr);
Delay_ms(1000);
Net_Ethernet_Intern_stackInitTCP();
while(1)
// Net_Ethernet_Intern_sendUDP( remoteIpAddr, 11000, 11000, "Hello from PIC18 Ethernet!", 48 );
again:
port = 1000;
while( Net_Ethernet_Intern_connectTCP(remoteIpAddr, 80, port, &clientSock) != 1)
Net_Ethernet_Intern_doPacket();
i = 0;
while (clientSock->state != 3)
i++;
if(i > 1000)
goto again;
wantToSent = 1;
sentFlag = 0;
//Call Net_Ethernet_Intern_UserTCP function
Net_Ethernet_Intern_startSendTCP(clientSock);
//Net_Ethernet_Intern_disconnectTCP(sock);
while(sentFlag != 1)
while( clientSock != 0)
for(i = 0; i < 1000; i++)
delay_ms(1);
