opensys
Newbie level 1
Hello folks,
I need to read from the mmc card a web page to display in web server, but i have problems loading files with like 300 chars or more.
I tested with 10 chars and is reading the file ok , but problem is when is bigger it freezes the pic or print random chars loop.
I need to put the file reading in chunks because the memory is 3kb
In this example i set the buffer to 512 bytes some of mmc card, and send it to serial console.
i use mikroc software.
unsigned long ii, file_size;
const BUFFER_SIZE = 512;
char BufferLarge[BUFFER_SIZE];
void go(){
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
Delay_ms(10);
Mmc_Fat_Init();
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV16, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
char hfilename[13] = "test.html";
Mmc_Fat_Assign(&hfilename, 0);
Mmc_Fat_Reset(&file_size);
while (file_size+1 > BUFFER_SIZE) {
for (ii=0; ii<BUFFER_SIZE; ii++)
Mmc_Fat_Read(BufferLarge + ii);
UART1_Write(BufferLarge[ii]);
file_size -= BUFFER_SIZE;
for (ii=0; ii<file_size; ii++)
Can any one help ?
thank you
void go(){
Delay_ms(10);
Mmc_Fat_Init();
Can any one help ?
thank you
