[PIC] PIC18F4550 LEDs control - USB Device - CDC - Basic Demo - C18 - PICDEM FSUSB + C#
HerrCat
Newbie level 3
Newbie level 3
Hello everybody!
In these days I am working on my project - controlling LEDs using CDC Basic demo firmware and C# application all from Microchip Solutions v2011-07-14 libraries.
I use rm18f4550 - MCHPUSB Bootload
I connected my device to USB port, pressed "Reset" button, then "Bootloader" button once. After that my computer recognized the device and asked for drivers - I installed drivers \Device - CDC - Basic Demo\inf. (I my PC it is shown as COM3 port). Everything worked.
Then I created .hex (firmware) file from the CDC Basic Demo project (Only change I made there is that i changed HID Bootload to MCHPUSB Bootload) and successfuly loaded it into my PIC18F4550 and restarted it.
Then I started the software (C# application - \Device - CDC - Basic Demo\PC Software Example) and connected my device by pressing "connect" buttom on the form. I wrote "1", pressed "Send Data" and I recieved "2", so everything worked fine. I also tried to press "Bootload" button on my PIC18F4550 board and it worked (program showed me "Button pressed--" in it's textBox).
But problem was when I tried to control LEDs connected to RD4-RD7. I can control only diodes on pins RD0-RD3.
In USB Device - CDC - Basic Demo - C18 - PICDEM FSUSB (Microchip MPLAB.project)
I opened
HardwareProfile - PICDEM FSUSB.h
and located this, where I simply added for more than 4 LEDS (default):
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
/** LED ************************************************************/
    #define mInitAllLEDs()      LATD &= 0xF0; TRISD &= 0xF0;
    #define mLED_1              LATDbits.LATD0
    #define mLED_2              LATDbits.LATD1
    #define mLED_3              LATDbits.LATD2
    #define mLED_4              LATDbits.LATD3
  [B]  #define mLED_5            LATDbits.LATD4
    #define mLED_6            LATDbits.LATD5
    #define mLED_7            LATDbits.LATD6
    #define mLED_8            LATDbits.LATD7[/B]
    #define mGetLED_1()         mLED_1
    #define mGetLED_2()         mLED_2
    #define mGetLED_3()         mLED_3
    #define mGetLED_4()         mLED_4
    #define mLED_1_On()         mLED_1 = 1;
    #define mLED_2_On()         mLED_2 = 1;
    #define mLED_3_On()         mLED_3 = 1;
    #define mLED_4_On()         mLED_4 = 1;
    #define mLED_5_On()         mLED_5 = 1;
    #define mLED_1_Off()        mLED_1 = 0;
    #define mLED_2_Off()        mLED_2 = 0;
    #define mLED_3_Off()        mLED_3 = 0;
    #define mLED_4_Off()        mLED_4 = 0;
    #define mLED_1_Toggle()     mLED_1 = !mLED_1;
    #define mLED_2_Toggle()     mLED_2 = !mLED_2;
    #define mLED_3_Toggle()     mLED_3 = !mLED_3;
    #define mLED_4_Toggle()     mLED_4 = !mLED_4;
    [B]#define mLED_5_Toggle()     mLED_5 = !mLED_5;
    #define mLED_6_Toggle()     mLED_6 = !mLED_6;
    #define mLED_7_Toggle()     mLED_7 = !mLED_7;
    #define mLED_8_Toggle()     mLED_8 = !mLED_8;[/B]
Then in main.c I located "ProcessIO" void and added:
void ProcessIO(void)
    BYTE numBytesRead;
    //Blink the LEDs according to the USB device status
    BlinkUSBStatus();
    // User Application USB tasks
    if((USBDeviceState < CONFIGURED_STATE)||(USBSuspendControl==1)) return;
    if(buttonPressed)
        if(stringPrinted == FALSE)
            if(mUSBUSARTIsTxTrfReady())
                putrsUSBUSART("Button Pressed -- \r\n");  When the button is pressed - this works
                [B]mLED_5_Toggle();[/B] Turns on/off LED 5?
                stringPrinted = TRUE;
    else
        stringPrinted = FALSE;
    if(USBUSARTIsTxTrfReady())
        numBytesRead = getsUSBUSART(USB_Out_Buffer,64);
        if(numBytesRead != 0)
            BYTE i;
            for(i=0;i<numBytesRead;i++)
                switch(USB_Out_Buffer[i])
                    case 0x0A:
                    case 0x0D:
                        USB_In_Buffer[i] = USB_Out_Buffer[i];
                        break;
                    default:
                    USB_In_Buffer[i] = USB_Out_Buffer[i] +1;
                   [B] mLED_5_Toggle();[/B]  After that I also tried it here-Everytime I send data it should turn on LED5... Not for me.
                        break;
            putUSBUSART(USB_In_Buffer,numBytesRead);
    CDCTxService();
}        //end ProcessIO
When I send data or just press the button, nothing happens - LED 5 is off... LEDs 5-7 simply don't work (I tried them all)...
HW scheme for better understanding:
My leds are connected on RD0 - RD7 (each one with 1K resistor)...
I don't know why there are just four LEDs that I can control... 1,2, mLED_3_Toggle(); or mLED_4_Toggle(); works fine...
I also tried change my PIC18F4550 (I have two chips) No change!
Thank you very much for your help!
HerrCat
you appear to initialse TRISD with
TRISD &= 0xF0;
to make a pin output you set it to 0 , try
TRISD &= 0;
HELLO brother try to change this command
TRISD &= 0xF0 to
TRISD &= 0x00 . may be your problem solved ..
Oh!!!
OK, my failure - I considered "0xF0" as "0"... :roll:
Changing it to "0x00 or 0" solved my problem! Thank You guys, Thank You very much!
I am so pleased!
Thank You again! :thumbsup:
Oh!!!
On RD7 I can only meassure 1.6 V on RD0-RD6 there is 1.72 V so my LEDs glows good...
Is it normal or some PIC18F4550 internal matter?
