[SOLVED] PIC18F4550 Help in configuration BITS
namees22
Junior Member level 2
Ernakulam
Hi ,
Now an started working with pic18f4550 went thru data sheets i found a lot of confusing things in it.So Configuration bits are not mentioned it.so i need help in Configuring the bits.(configuration bits). So i need to know where i could find it..thanx in advance
#include "p18f4550.h"
        #pragma config PLLDIV   = 5         // (20 MHz crystal on PICDEM FS USB board)
        #pragma config CPUDIV   = OSC1_PLL2
        #pragma config USBDIV   = 2         // Clock source from 96MHz PLL/2
        #pragma config FOSC     = HSPLL_HS
        #pragma config FCMEN    = OFF
        #pragma config IESO     = OFF
        #pragma config PWRT     = OFF
        #pragma config BOR      = ON
        #pragma config BORV     = 3
        #pragma config VREGEN   = ON      //USB Voltage Regulator
        #pragma config WDT      = OFF
        #pragma config WDTPS    = 32768
        #pragma config MCLRE    = ON
        #pragma config LPT1OSC  = OFF
        #pragma config PBADEN   = OFF
        #pragma config CCP2MX   = ON
        #pragma config STVREN   = ON
        #pragma config LVP      = OFF
        #pragma config ICPRT    = OFF       // Dedicated In-Circuit Debug/Programming
        #pragma config XINST    = OFF       // Extended Instruction Set
        #pragma config CP0      = OFF
        #pragma config CP1      = OFF
        #pragma config CP2      = OFF
        #pragma config CP3      = OFF
        #pragma config CPB      = OFF
        #pragma config CPD      = OFF
        #pragma config WRT0     = OFF
        #pragma config WRT1     = OFF
        #pragma config WRT2     = OFF
        #pragma config WRT3     = OFF
        #pragma config WRTB     = OFF       // Boot Block Write Protection
        #pragma config WRTC     = OFF
        #pragma config WRTD     = OFF
        #pragma config EBTR0    = OFF
        #pragma config EBTR1    = OFF
        #pragma config EBTR2    = OFF
        #pragma config EBTR3    = OF
        #pragma config EBTRB    = OFF
hi,
thnx for the reply...may i ask u one thng.. y al these bits shuld set if ever i need a single lcd program i need to have Mc crystal only selcted dnt i ,how wil i understand al those fully
