embedded_galaxy
hi,
working with TMP275 temperature sensor interfacing with pic18f4550.
my code is as follows :
pull up resistors are on slave device , this slave device is perfectly working with some CM4 device.
issue :
my data is send ok to slave but while reading data master can not send ACK BIT to slave
it will stuck in i2c_master_ack(I2C_DATA_ACK);
thanks,
Embedded_galaxy
// I2C Bus Control Definition
#define I2C_DATA_ACK 0
#define I2C_DATA_NOACK 1
#define I2C_WRITE_CMD 0
#define I2C_READ_CMD 1
#define I2C_START_CMD 0
#define I2C_REP_START_CMD 1
#define I2C_REQ_ACK 0
#define I2C_REQ_NOACK 0
unsigned char config;
unsigned char temp_low;
signed char temp_high;
unsigned int fraction;
int device_found = 0;
int init_temperature_sensor(void)
TRISBbits.TRISB0 = 1; //SET OIN AS A INPUT
TRISBbits.TRISB1 = 1; //SET OIN AS A INPUT
// the configuration of the functions of port pins
ADCON1=0b00001111; // digital port configured
SSPSTAT=0x80; // SLEW RATE CONTROL DISABLED FOR std mode (100khz)
SSPCON1=0x28; // i2c master mode, serial synch enable
SSPCON2=0x00;
SSPADD = 19; // 8MHZ for 100Khz
void i2c_idle(void)
// Wait I2C Bus and Status Idle (i.e. ACKEN, RCEN, PEN, RSEN, SEN)
while (( SSPCON2 & 0x1F ) || ( SSPSTATbits.R_W));
void i2c_start(unsigned char stype)
i2c_idle(); // Ensure the I2C module is idle
if (stype == I2C_START_CMD) {
SSPCON2bits.SEN = 1; // Start I2C Transmission
while(SSPCON2bits.SEN);
} else {
SSPCON2bits.RSEN = 1; // ReStart I2C Transmission
while(SSPCON2bits.RSEN);
void i2c_stop(void)
// Stop I2C Transmission
SSPCON2bits.PEN = 1;
while(SSPCON2bits.PEN);
unsigned char i2c_slave_ack(void)
// Return: 1 = Acknowledge was not received from slave
// 0 = Acknowledge was received from slave
return(SSPCON2bits.ACKSTAT);
void i2c_write(unsigned char data)
// Send the Data to I2C Bus
SSPBUF = data;
if (SSPCON1bits.WCOL) // Check for write collision
return;
while(SSPSTATbits.BF); // Wait until write cycle is complete
void i2c_master_ack(unsigned char ack_type)
SSPCON2bits.ACKDT = ack_type; // 1 = Not Acknowledge, 0 = Acknowledge
SSPCON2bits.ACKEN = 1; // Enable Acknowledge
while (SSPCON2bits.ACKEN == 1);
unsigned char i2c_read(void)
i2c_idle();
// Enable Receive Mode
SSPCON2bits.RCEN = 1; // Enable master for 1 byte reception
while(SSPSTATbits.BF); // Wait until buffer is full
return(SSPBUF);
void Write_TMP275(unsigned char reg_addr,unsigned char data) {
// Start the I2C Write Transmission
i2c_start(I2C_START_CMD);
// Write TMP275 I2C OP Code
i2c_write(TMP275_ADDRESS|I2C_WRITE_CMD);
// Sending the Register Address
i2c_write(reg_addr);
// Write data to TMP275 Register
i2c_write(data);
i2c_stop();
unsigned char Read_TMP275(unsigned char reg_addr,unsigned char *dval) {
unsigned char hidata,lodata;
char decval[]={0,25,50,75};
/*SEND REG_ADDR*/
// Write TMP275 I2C ddress
i2c_stop();
// i2c_idle();
delay(55); //10bits resolution 55ms
/*READ*/
// Read tmp275 I2C Temp Sensor Control Byte - Read
i2c_write(TMP275_ADDRESS|I2C_READ_CMD);
// Get the High Byte of TMP275 I2C Temp Sensor
hidata=i2c_read();
// Send Acknowledge to the Slave
[HTML] [B]i2c_master_ack(I2C_DATA_ACK);[/B] [/HTML]
// Get the Low Byte of TMP275 I2C Temp Sensor
lodata=i2c_read();
// Send No Acknowledge to the Slave
i2c_master_ack(I2C_DATA_NOACK);
i2c_stop();
// Return 10-bit Temp Sensor Data
*dval=decval[lodata >> 6]; // Convert lower data to decimal.
return(hidata);
void set_conversion_bit(unsigned char conversion)
Write_TMP275(CONFIGURATION_REGISTER,conversion);
void Read_TEMERATURE(void)
unsigned char recievebytes[2];
//write pointer register 00000000 to select temp register to read temperature
/*Read high byte of temperature and Read low byte of temperature*/
Read_TMP275(TEMPERATURE_REGISTER,recievebytes);
temp_high =recievebytes[0]; // high byte
temp_low = recievebytes[1]; //low byte
fraction=(temp_low>>4)*625/1000;//calculate fraction part of temperature from LSB
Write_TMP275(CONFIGURATION_REGISTER,POWER_UP); // read device
if(I2CRead_Buffer[0] == 0)
//device found
device_found = 1;
set_conversion_bit(12);
issue :
thanks,
Embedded_galaxy
