PIC18f4520 Timer0 Interrupt Problem
Amardeep
Junior Member level 3
Hi
I am Using PIC18f4520 Micro controller.
I want to Generate timer interrupt after every 1sec.
I am using internal clock for timer, Internal oscillator at 125khz, Timer0 in 16-bit Mode
please guide me how to calculate exact value for TH0 and TL0 register
amardeep.singh190@gmail.com
You could do it using Timer 0 in 8 bit mode.
125KHz / 4 = 31,250 /* Timer increment frequency. */
1 / 31250 = 0.000032 /* Increment time. */
0.00032 * 256 = 0.008192 /* Using 1:256 prescaler */
1 / 0.008192 = 122 /* counts for 1 second. */
256 - 122 = 134 /* Timer pre load value */
TMR0 = 134
If you pre-load the timer in the interrupt routine, you should have a 1 second interrupt.
Use mplab sim and the stopwatch to fine tune.
Thanks Alot .. I Got Every Point ...
Hello Btbass
when i simulate the code using MPLAB SIM the time of timer inerrupt is random not fix .. what should be the problem ?
here is attachment of my code View attachment TIMER.txt
This is My Code ....
void chk_isr();
void TIMER0_ISR(void);
/*******ISR of 0x08 Location********/
#pragma code My_HiPrio_Int=0x08
void My_HiPrio_Int(void)
_asm
GOTO chk_isr
_endasm
#pragma code
#pragma interrupt chk_isr
/*****Check ISR Starts*******/
void chk_isr(void)
if( INTCONbits.TMR0IF==1)
TIMER0_ISR();
void main()
OSCCON=0X14;
RELAY=0X00;
check=0x0000;
LED_DIR=0;
LED=0;
T0CON=0x46; // timer0 8bit with prescalar for 256
TMR0L=0x86;
INTCONbits.GIE=1; // ENABLE all INT
INTCONbits.TMR0IF=0; // FLAG
INTCONbits.TMR0IE=1; // ENABLE TIMER INT
T0CONbits.TMR0ON=1; // TIMER ON
while(1)
LED=0;
++check;
if(check==0x46)//70
LED=1;
Delay(); // Millisecond delay
Here is a free tool that you can just input the required interrupt frequency into and it will generate all the necessary code to initialise the timer registers for you.
Hope this is helpful.
/Pheetuz
Hi
recheck SCS1:SCS0: System Clock Select bits with data sheet
Because in your code T0CON=0x46;
That means you are using 1:128 prescale value(Fosc/4/128)
T0CS bit=0, Internal instruction cycle clock (CLKO).
The IDLEN bit (OSCCON<7>) controls CPU clocking, while the
SCS1:SCS0 bits (OSCCON<1:0>) select the clock
source.
Check POWER-MANAGED MODES with the datasheet if it is correct
You need to pre-load the timer in the interrupt routine so there is a count of 122 before the next interrupt.
  INTCONbits.TMR0IF = 0;
  TMR0L = 134;	/* Pre Load timer */
  ++check;
  if(check==0x46)//70
   LED=1;
thnx evry1 specially @btbass for the big help mate... my problem has been solved... thnx for giving me time n helping in solving the issue.. help appreciated
