PIC18F4520 program to check input states
hussong1555
Member level 1
USA
I wrote the following code for C18 compiler. basically what I am trying to accomplish is the have an LED light up at RD0 when RA0 is high then turn off when RA0 is low. then the same for RD1 and RA1.
#define HI 1
#define LO 0
//Header files
#include <p18f45k20.h>
#include <delays.h>
//Define variables
char servoA_status;
char servoB_status;
char LED_A;
char LED_B;
void main(void)
	TRISA = 0b00000011; 				//PORTA bit 7:2 to output (0); bits 1:0 are inputs (1)
	TRISB = 0b00000000;					//PORTB bit 7:0 to output (0);
	TRISC = 0b00000000;					//PORTC bit 7:0 to output (0);
	TRISD = 0b00000000;					//PORTD bit 7:0 to output (0);
	LATA = 0b00000000;					//set all outputs to low
	LATB = 0b00000000;					//set all outputs to low
	LATC = 0b00000000;					//set all outputs to low
	LATD = 0b00000000;					//set all outputs to low
	while (1)
		LATDbits.LATD7 = ~LATDbits.LATD7; // toggle LATD
	//	Delay1KTCYx(50);	// Delay 50 x 1000 = 50,000 cycles; 200ms @ 1MHz
		servoA_status=PORTAbits.RA0;
		servoB_status=PORTAbits.RA1;
		if (servoA_status=HI)
			LATDbits.LATD0 = HI; // turn on LED
	//		Delay10KTCYx(50);	// Delay 50 x 10000 = 500,000 cycles; 2000ms @ 1MHz
		else
			LATDbits.LATD0 = LO; // turn off LED
		if (servoB_status=HI)
			LATDbits.LATD1 = HI; // turn on LED
		else
			LATDbits.LATD1 = LO; // turn off LED
what I am getting is LED 0 and 1 are always on regardless of the state of RA0 and RA1. Where am I going wrong????
hussong1555
Member level 1
USA
Thanks for the help, i will try it monday morning
