PIC18f4520 I2C module interfacing problems..need urgent help
ALIARIF93
Junior Member level 1
Hello,
does anyone know any site related to I2C module explanation in PIC 18f4520?I want to contr
bmb_10
Member level 1
Colombia
Hello ALIARIF93, you can find the explanation of use of the I2C bus, for PIC18F4520 in the datasheet on page 170.
Greetings!
ALIARIF93
Thanx...But datasheet did'nt explain it with examples...
any other link??
bmb_10
Member level 1
Colombia
Hello ALIARIF93, examples depend on the programming language you are using and the device you are communicating with the microcontroller. Normally, in the datasheets of the device to which you want to communicate, there is the protocol to use. Which compiler are you using and which device you want to communicate?
Greetings!
ALIARIF93
i'm using IMU module with PIC18f4520 with I2C module using MPLAB C18 compiler!!!!!
bmb_10
Member level 1
Colombia
Hello ALIARIF93, unfortunately I don't use MPLAB C18 and therefore I can't help you. Normal in the modules that communicate via I2C, is to see the command sequence in the datasheet for the device, and transfer this information to the programming language you are using. Anyway, for someone else can help, you would post the site where to find the datasheet of the IMU module you are using, because it appears many different IMU modules searching in Google.
Greetings!
