oxygen8d
Newbie level 2
Hello forum
I am working on a project, I am currently trying to get some LCD code attached to drive my LCD, the LCD is HD44780 compatible and the driver is written for it. However, my circuit has a 20Mhz crystal so I think the delays that are defined at the beginning of the code must be incorrect. Could someone please help with this. I have my LCD wired like this:
RB0 -> D4
RB1 -> D5
RB2 -> D6
RB3 -> RS
RB5 -> E
I have a 10k pot connected to Vo for contrast. I am getting a line of solid balck boxes when the contrast is fully up. I have the required curent going to the backlight. So I think it must be my code: I need help with the delay as the code was written for a PIC16F876 with a clock of 3.876Mhz.
Thanks in advance
Jim
RB0 -> D4
RB1 -> D5
RB2 -> D6
RB3 -> RS
RB5 -> E
Thanks in advance
Jim
#include <p18f452.h>
// LCD Driver module
// LCD module is connected as follows:
// RB0 - RB3 -> DB4 - DB7
// RB4 -> RS
// RB5 -> E
// define constants
#define RS PORTBbits.RB4 // RS control line is bit 4 of port B
#define E PORTBbits.RB5 // E control line is bit 5 of port B
#define LCD_INIT 0x33 // command to initialise LCD display
#define FOUR_BIT_MODE 0x32 // command to make the LCD transfer instructions and data in 4 bit chunks rather than 8
#define TWO_LINE_MODE 0x2c // command to put the LCD in two-line mode
#define MOVE_AFTER_WRITE 0x06 // command to increment cursor position automatically
#define DISPLAY_INIT 0x0c // command to turn display on, switch off the cursor and stop it blinking
#define WRITE_DELAY 200 // constant used to set write delay time (50 us required)
#define BIT_DELAY 2 // constant used to set pulse duration (a few us required)
#define INST_DELAY 1000 // constant used to det instruction delay (1.53 ms required)
//#define WRITE_DELAY 270 // constant used to set write delay time (50 us required) 200ns * 270 = 54us
//#define BIT_DELAY 15 // constant used to set pulse duration (a few us required) 200 ns * 15 = 3us
//#define INST_DELAY 3000 // constant used to det instruction delay (1.53 ms required) 200ns * 7500 = 1.5ms
// FUNCTION EXTERNAL FUNCTION REFERENCES
// FUNCTION ADVANCE DECLARATIONS
void LCD_write(unsigned char c, unsigned char rs); // basic write function (instruction or data depending on rs)
void LCD_initialise(void); // send initialisation commands to LCD
void LCD_clear(void); // function to clear LCD display and home the cursor
void LCD_delay(unsigned int D); // function to generate a delay
void pulse_E(void); // function to pulse E pin high then low
void LCD_putch(unsigned char c); // character output routine
void LCD_puts(unsigned char *s); // Writes string s to LCD
void LCD_cursor (unsigned char x, unsigned char y ); // Moves cursor to x,y
void LCD_cursor_on (void); // Turn cursor on
void LCD_cursor_off (void); // Turn cursor off
void LCD_display_value (unsigned int value); // Display a numeric value (0-999)
// Initialise LCD module
// INITIALISE LCD
LCD_write(LCD_INIT, 0); // command to initialise LCD display, (RS = 0)
LCD_delay(INST_DELAY); // call function to wait until LCD has completed instruction
// Set LCD for 4-bit mode
LCD_write(FOUR_BIT_MODE, 0); // command to set LCD in 4-bit mode, (RS = 0)
// set LCD in up for two lines
LCD_write(TWO_LINE_MODE, 0); // command to set LCD for two lines, (RS = 0)
// Select move after write
LCD_write(MOVE_AFTER_WRITE, 0); // command to set LCD to increment cursor pos. automatically (RS = 0)
// Configure display & cursor
LCD_write(DISPLAY_INIT, 0); // command to configure display, (RS = 0)
LCD_clear();
// LCD_write() function is a basic write subroutine that could be an instruction or data
unsigned char temp; // temporary variable to hold ms 4 bits of c
unsigned char RSmask = 0; // used to set or reset bit 4 of PORTB
unsigned char TRISB_BAK; // Current status of port B data direction register
// INITIALISATION
// RP0 = 1; // get ready to write to data direction registers
TRISB_BAK = TRISB; // Get current state of TRISB register
TRISB = 0x00; // Set PORTB bits 0 - 7 as outputs
// RP0 = 0; // get ready to use ports
if (rs == 1) RSmask = 0x10; // set up bit mask for RS line
// set MS 4 bits of c up on RB0 - RB3
temp = c;
LATB = (temp >> 4) | RSmask; // shift MS 4 bits into LS 4 bits, set/rst RS and present on PORTB
// pulse E high then low
pulse_E(); // call function to strobe data to LCD module
// set LS 4 bits up on RB0 - RB3
LATB = (c & 0x0F) | RSmask; // present LS 4 bits on RB0 - RB3 and set/rst RS line
pulse_E(); // Call function to strobe data to LCD module
LATB = 0x10; // set E high again to avoid annoying LED flicker
TRISB = TRISB_BAK; // Restore state of TRISB register
//putch(c) function is character output routine
LCD_write(c, 1); // call basic LCD write routine with RS high (send data)
LCD_delay(WRITE_DELAY); // call function to wait until LCD has completed write operation
//LCD_clear() function is an instruction to clear all data from LCD display and return cursor to beginning of display
LCD_write(1, 0); // call basic write function with instruction 1, (clear display) and RS 0, (write instruction)
LCD_delay(INST_DELAY); // Call function to wait until LCD has completed instruction
LCD_write(2, 0); // call basic write function with instruction 2, (cursor home) and RS = 0, (write instruction)
// function to pulse E pin high then low with a duration of a few usecs
void pulse_E(void)
// set E high and wait a bit
E = 1; // set E line high
LCD_delay(BIT_DELAY); // pulse delay for E
// set E low and wait a bit
E = 0; // set E line low
// Function to generate a delay
unsigned int counter; // variable used as delay loop counter
for (counter = 0; counter < D; counter++);
// Function to write null terminated string to LCD display
unsigned char c = 255;
unsigned char i = 0;
while ((c > 0) && (i < 16)) //16 is the maximum length of the string
c = s[i];
if (c != 0) LCD_putch(c);
i++;
if ( y==0 )
/* position for line 0 */
y=0x80 ;
else
/* position for line 1 */
y=0xc0 ;
LCD_write( y+x, 0) ;
void LCD_cursor_on ( void ) // Turn cursor on
LCD_write(0x0f, 0);
void LCD_cursor_off ( void ) // Turn cursor off
LCD_write (0x0c, 0);
void LCD_display_value ( unsigned int value )
unsigned char hunds, tens, units ;
/* first get the digits */
units = value % 10 ;
value = value / 10 ;
tens = value % 10 ;
hunds = value % 10 ;
/* now display them */
LCD_putch('0' + hunds ) ;
LCD_putch('0' + tens);
LCD_putch('0' + units);
