PIC18f452 C-Code problem for C18 tool suite
talhataj
Newbie level 3
Hi Guys,
I m new to C language and currently working on programming of a PIC18f452 microcintroller. To get a start, i wrote a simple LED blinking code on MPLAB using C18 toolsuite, the code seems to be compiling and hex file is created without any errors, but after burning it on the controller the LED doesnt seem to flash, Please help
#include <stdlib.h>
#include <stdio.h>
#include <p18f452.h>//definitions of input/output pins
#include <portb.h>//functions to control pull-up resistors and interrupts
#pragma config WDT = OFF, OSC = XT, LVP = OFF, STVR = OFF, DEBUG = OFF, WRT0 = OFF, WRT1 = OFF, CP0 = OFF, CP1 = OFF, CPD = OFF, BOR = OFF
#include <delays.h> //This loads the delay functions. (See the library document.)
void main()
PORTA = 0x00; //set RA0-RA5 low
TRISA = 0x00; //set PORTA to output
//superloop
while(1)
PORTA = !PORTA;
//delays(250);
Delay1KTCYx(1000000000);
//_delay(250);
Regards
Talha
Is it
 PORTA = !PORTA;
or
 PORTA = ~PORTA;
? Also you should use LATA instead of PORTA.
