icefire91
Newbie level 6
I have design a pic to measure Voltage and current together. it work perfectly normal on Proteus simulation. But when I fix it up to a bread board it does not work properly. I have two analogue input an0 and an1. an0 is for current and an1 is for voltage. so when i insert the wire from the current circuit into an0 the voltage and the current value displayed on the lcd is wrong. so when i remove the wire connected to an0, the current sensor, the voltage value display on the lcd is correct. Can anyone help me.
