megacrypto
Junior Member level 2
- Joined
- Sep 21, 2009
- Messages
- 20
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,283
- Activity points
- 1,425
I just moved to PIC18 to maybe make use of the better functions XC8 has for them (especially SPI) and I got the PIC18F252. Now before I get to SPI, I have to through all the initial learning curve step, which begin with flashing an LED.
here is my code:
config.h
main.c
Im using an external 16MHz crystal.
When the program runs, LED 2 (LATB7) goes on and LED 1 (LATB6) stays off. It should be alternating, but it doesn't
Thanks you all
here is my code:
config.h
// PIC18F252 Configuration Bit Settings
// CONFIG1H
#pragma config OSC = HS // Oscillator Selection bits (RC oscillator w/ OSC2 configured as RA6)
#pragma config OSCS = OFF // Oscillator System Clock Switch Enable bit (Oscillator system clock switch option is disabled (main oscillator is source))
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = OFF // Brown-out Reset Enable bit (Brown-out Reset disabled)
#pragma config BORV = 20 // Brown-out Reset Voltage bits (VBOR set to 2.0V)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 128 // Watchdog Timer Postscale Select bits (1:128)
// CONFIG3H
#pragma config CCP2MUX = ON // CCP2 Mux bit (CCP2 input/output is multiplexed with RC1)
// CONFIG4L
#pragma config STVR = OFF // Stack Full/Underflow Reset Enable bit (Stack Full/Underflow will not cause RESET)
#pragma config LVP = OFF // Low Voltage ICSP Enable bit (Low Voltage ICSP disabled)
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000200-001FFFh) not code protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) not code protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) not code protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (006000-007FFFh) not code protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot Block (000000-0001FFh) not code protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000200-001FFFh) not write protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) not write protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) not write protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (006000-007FFFh) not write protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0001FFh) not write protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000200-001FFFh) not protected from Table Reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) not protected from Table Reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) not protected from Table Reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (006000-007FFFh) not protected from Table Reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0001FFh) not protected from Table Reads executed in other blocks)
main.c
#define _XTAL_FREQ 16000000 //4Mhz FRC internal osc
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#include "config.h"
void main(void) {
INTCON = 0;
INTCON2 = 0;
INTCON3 = 0;
TRISB6 = 0;
TRISB7 = 0;
while(1){
LATB6 = 0;
LATB7 = 1;
for ( int i = 0; i < 100; i++ ){
__delay_ms(10);
LATB6 = 1;
LATB7 = 0;
__delay_ms(10);
Thanks you all
