[SOLVED] PIC18F1230 ICSP Programming
panos_papajohn
Member level 2
Hi everyone,
I am using PIC3 kit to program a PIC18f1230.
#include <stdio.h>
#include <delays.h>
#pragma config OSC=HS, WDT=OFF, IESO=OFF, XINST=OFF
void main (void)
{TRISB=0;
PORTB=0x00;
 //Delay10KTCYx(0);
 PORTB=0xFF;
//Delay10KTCYx(0);
while (1)
This is the code I wrote. When I connect a led to the portB nothing happens.
Of course the current should be taken into account, but the thing is that when I measure the voltage on every pin of the portB I get 0 volts. Did i do something wrong?
Thanks for the help
Panos
raco_rage
Member level 3
try to check PORTB output after removing PORTB = 0x00. Right now, it'll be going so fast in the while loop that you cannot measure it.
