adrian_miranda13
i have a bit problem in using the uln2003a,
the following are the pin assignments
pin 1 = +5v
pin 8 = ground
pin 9 = +12v
what would be the output voltage when i will measure the pin 16?and the voltage measured in this pin will be enough to be a source of a 6v relay?
thanks in advance...
pin 1 = +5v
pin 8 = ground
pin 9 = +12v
