pic16f877a + spi + 93LC46A-I/OT EEPROM
mayasunny
Member level 3
Hi members,
i'm working on pic16f877a micro controller, i want to interface 96LC46A-I/OT EEPROM with pic controller using spi module.
my pic oscillator is about 20MHz, and eeprom Fclk is max 2MHz.
now im unable to generate clock at SCL pin , i don't know why. i checked spi separately, it is generating clock signal, but when i interface with external eeprom problem comes.any help from members?
"SCL" usually is an "I2C" pin, not an "SPI" pin. Please check this.
And for the rest: How do you think we can help you without showing your code and schematic?
Check your connections ! Obviously some mistake in your wiring.
But also give more details of "problem comes". What problem exactly ?
Thanks for your reply ,
klausST "SCL/SCK" is the clock pin for both SPI & I2C according to pic16f877a datasheet.
i made a mistake in setting bit to CKE pin, i made this pin high now i can see the clock from master. now the problem im facing is whatever the data i'm writing to eeprom is showing as 0xFF, (SSPBUF = 0XFF), i don't know why,
below is my spi code can you check please
#pragma config FOSC = HS                                 // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF                                // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = ON                                // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = ON                                // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF                                 // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF                                 // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF                                 // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF                                  // Flash Program Memory Code Protection bit (Code protection off)
#include <xc.h>
#define _XTAL_FREQ 20000000
//SPI lines
#define CS RA5 //Chip select ON RA5
#define MOSI RC5 //Master Out Slave In
#define MISO RC4 //Master in slave out
#define SCK RC3 //Clock
/*SPI_COMMANDS
#define READ 0b00001100;
#define WRITE 0b00001010;
#define EWEN  0b10001001;
#define EWDS 0b00001000;
#define ERASE 0b00001110;*/
unsigned char HiByte;                                        //High Order Byte
unsigned char LoByte;                                        //Low Order Byte
unsigned char HiData;                                        //Hi Data Byte (upper 8 bits of word)
unsigned char ReadData[1];                                   //Holds Device data being read back
unsigned char Length;                                        //Number of Bytes to read (1 for x8 mode)
unsigned char Result,rxdata;
void SPI_init(void);                                         // Init. function
void Ewen(void);                                             // Erase/Write Enable function
void Ewds(void);                                             // Erase/Write Disable function
void SPI_write_cmd(unsigned char, unsigned char, unsigned char);            // 8-bit Write function
unsigned char DataRdyMwire(void );
char SPI_Write(char);
unsigned char SPI_Read (unsigned char, unsigned char, unsigned char , unsigned char);
char getdata( unsigned char, unsigned char );
void main(void)
    HiByte = 0x0A;                                                //Dummy Zero's, Start Bit and Op Code for Byte Write
    LoByte = 0x10;                                                //Address bits for 93LC66C
    HiData = 0x5A;                                                  //Upper 8 bits of Data word
    Length = 0x01;                                                  //Number of bytes to read  (1 for x8)
    while(1){
    SPI_init();
    Ewen();
    //  __delay_ms(1);
    SPI_write_cmd(HiByte, LoByte, HiData);
   // __delay_ms(1);
    Ewds();
    HiByte = 0x0C;                                                //Changes OpCode from Write to Read for next function
    __delay_us(1);
    SPI_Read(HiByte, LoByte, ReadData, Length);
    while(1);                                                    //Loop here forever
void SPI_init()
  //  ADCON1 = 0X4F;
    TRISC5 = 0;                                                  // Configure PORTC I/O, MOSI
    TRISC3 = 0;                                                  // Configure PORTC I/O, CLK
    TRISC4 = 1;                                                  // Configure PORTC I/O, MISO
    PORTA = 0;                                                   // Clear all PORTA pins
    TRISA = 0;
    SSPSTAT = 0b01000000;
    SSPCON = 0b00100001;
void Ewen(void)
    CS = 1;                                                     //Select Device
    SPI_Write(0x09);                                            //EWEN Command
    SPI_Write(0x08);
     __delay_us(1);
    CS = 0;                                                     //Deselect Device
char SPI_Write(char incoming)
    SSPBUF = incoming;                                          //Write the user given data into buffer
    if (SSPCONbits.WCOL == 1)                                   // test if write collision occurred
         return(-1);
    }                                                           // if WCOL bit is set return negative #
    else
        while(!SSPSTATbits.BF );                                // wait until bus cycle complete
        //rxdata = SSPBUF;
        return (0);                                             // if WCOL bit is not set return non-negative#
void SPI_write_cmd(unsigned char HiByte, unsigned char LoByte, unsigned char HiData)
    CS = 1;                                                     // Select Device
    SPI_Write(HiByte);                                            // Send HiByte (Dummy bits, SB, and Op Code)
    SPI_Write(LoByte);                                            // Send LoByte (Address for the 93LC66C)
    SPI_Write(HiData);                                            // Send HiData to EEPROM
    CS = 0;                                                       // Deselect Device and initiate write
    __delay_us(1);
    while (!DataRdyMwire());                                    // Wait for Write to complete
    CS = 0;                                                        // Deselect device
   // __delay_us(1);
unsigned char DataRdyMwire(void)
    if(PORTCbits.RC4)                                             // test if DO line is high
      return (1);                                                 // return ready = true
    else
      return (0);                                                 // else ready = false
void Ewds(void)
     SPI_Write(0x08);                                           //EWDS Command to disable write/erase operation
     SPI_Write(0x00);
      __delay_us(1);
unsigned char SPI_Read(unsigned char HiByte, unsigned char LoByte, unsigned char ReadData, unsigned char Length )
    LoByte = LoByte << 1;
    SPI_Write( HiByte );                                          // Send Read OpCode
    SPI_Write( LoByte );                                          // WRITE word address to EEPROM
    Result=getdata(ReadData, Length);                             // Reads 1 byte
    __delay_us(1);
char getdata( unsigned char ReadData, unsigned char length )
    while ( length )                                              // stay in loop until length = 0
      SSPBUF = 0x00;                                              // initiate bus cycle
      while(!SSPSTATbits.BF );                                    // wait until byte has been received
      __delay_us(1);
      ReadData = SSPBUF;                                          // save byte
      length--;                                                   // reduce string byte count by 1
  return(ReadData);
</xc.h>
Many points can come to mind. However most important one is that the Instruction set for your ic is 9- bits length. I cannot see where/ how these 9- bits are being formed or managed.
i'm in confusion, in eeprom datasheet they mention like this s.b(startbit),opcode,address(A6-A0) , this total comes to 10bits
but you are saying 9th bit, can you explain it little clear
one more thing my eeprom size is 1kb
I am simply looking at datasheet of 93LC46A, which is what you mentioned. Clearly mentions 9-bit in many places. Also, it's A5.. A0 and not A6.. A0
sir, please check X8 organization, ORG=0
Clearly you are referring to datasheet of some other device. Please cross-check and confirm precisely which eeprom you are talking about.
Okay, I think I have located the variant you are using.
So back to my point, where are you handling 10-bits?
Start with functions EWEN and EWDS
EWEN 1(S.B) 00(OP) 1 1 XXXX (A6-A0) for this
SPI_Write(0x04); //EWEN Command
SPI_Write(0xC0);
im little confused how to handle this 10bits
SPI_Write(0x04); //EWDS Command to disable write/erase operation
SPI_Write(0x00);
I don't know how your SPI_write works. It is probably byte oriented. Also what control is there for clock speed?
You could write your own bit-banged routines which handle non 8-bit transfers and also allow control of clock speed below maximum of chip.
now i'm operating it with 1.25MHz frequency
The EEPROM says that it is "microwire compatible" and while mirowire and SPI are related, they are NOT the same.
You haev two choices: 1) use a newer EEPROM that has a standard SPI or I2C interface (Microchip and many others make these in abundance) which will let you use the MCU's MSSP module; 2) bit-bang the interface as the MSSP module ONLY works with 8-bit values and you need the 9/10/18/25/whatever clocks for each transfer.
Susan
OK - I had not seen that. Thanks for pointing it out.
AN1023 (linked from the EEPROMs data sheet page you linked to) certainly shows the MSSP module being used. What it also shows is that the EEPROM will ignore leading '0's in the MSByte which I did not pick up from the data sheet itself. Also many (other) devices can be a but sensitive to too many clocks - looks like this one is not.
Given that Application Note, you should now be all set.
Susan
Interesting AppNote. Especially this line quoted from the text "Since the Microwire protocol is not native to the MSSP module, a version of SPI mode 0,0 has been implemented and works within the data sheet specifications for Microwire".
Also the purpose of that Start-Bit (SB) becomes clear.
