masab_ahmad
Member level 1
Hi all, i made a code to drive 2 DC motors. the PWM pins are connected to a 1k Resistor, which is connected to the gate of a irf510 mosfet with the motor connectd to it(is this ok?). ive attached the code here, it should vary the PWM with variations in the ADC value stored in the 'temp' variables. But it doesnt seem to vary the PWM, (the adc voltages vary just fine), anything wrong with the code? its in mikroC.
* MAIN LOOP
unsigned int temp0;
unsigned int temp1;
void main()
ADCON1 = 0 ; // enables ADC
TRISA = 0xff ; // PORTA as inputs
PORTA = 0 ;
TRISC = 0 ; // PORTC as outputs
PORTC = 0 ;
// init PWM Channel : 20 Khz, 90% duty cycle
PWM1_Init(20000) ;
PWM1_Set_Duty(200) ;
PWM2_Init(20000) ;
PWM2_Set_Duty(200) ;
PWM1_Start(); // enable PWM output
PWM2_Start();
// forever loop
for(;
while((Adc_Read(0) && Adc_Read(1)) > 1) //pulses detected always
temp0 = Adc_Read(0); //reading adc ports for ultrasonic pulses
temp1 = Adc_Read(1);
if(temp0 < 655) //car too far from obstacle
PWM1_Set_Duty(200);
else if((temp0 > 655) &&(temp0 < 700)) //car far from obstacle
PWM1_Set_Duty(150);
else if((temp0 < 750) && (temp0 > 700)) //car far from obstacle
PWM1_Set_Duty(120);
else if((temp0 < 800) && (temp0 > 750)) //car medium from obstacle
PWM1_Set_Duty(100);
else if((temp0 < 900) && (temp0 > 800)) //car near to obstacle
PWM1_Set_Duty(0);
PWM2_Set_Duty(200);
if(temp1 < 460) //car too far from obstacle
PWM1_Set_Duty(200);
else if((temp1 < 500) && (temp1 > 460)) //car too far from obstacle
PWM2_Set_Duty(150);
else if((temp1 < 550) && (temp1 > 500)) //car far from obstacle
PWM2_Set_Duty(120);
else if((temp1 < 600) && (temp1 > 550)) //car medium to obstacle
PWM2_Set_Duty(100);
else if((temp1 < 780) && (temp1 > 600)) //car near to obstacle
PWM2_Set_Duty(0);
PWM1_Set_Duty(200);
Delay_ms(10); // 1 millisecond delay before next sample
* MAIN LOOP
unsigned int temp0;
unsigned int temp1;
void main()
PORTA = 0 ;
PORTC = 0 ;
PWM1_Init(20000) ;
PWM2_Init(20000) ;
PWM2_Start();
// forever loop
for(;
PWM1_Set_Duty(200);
PWM1_Set_Duty(150);
PWM1_Set_Duty(120);
PWM1_Set_Duty(100);
PWM1_Set_Duty(0);
PWM2_Set_Duty(200);
PWM1_Set_Duty(200);
PWM2_Set_Duty(150);
PWM2_Set_Duty(120);
PWM2_Set_Duty(100);
PWM2_Set_Duty(0);
PWM1_Set_Duty(200);
