Register Log in
Pic16f877a push button
Hello!
My Circuit Contains a PIC16F877A. PIN RB0 and PB1 is connected to two mom switches with pull-ups and pin RD0 is configured as output pin and is connected to a relay via uln2003a. The mikroBasic code below is not working properly. When I press sw2 the relay gets turned ON but the relay turns off after 3-4 secs. what might be the problem.
Code Basic4GL - [expand]
8
9
10
11
12
13
14
15
16
main:
     TRISB = $FF
     TRISD = $00
     PORTB = 0
     PORTD = 0
     while(1)
         if(Button(PORTB, 0, 10, 0)) then
            PORTD.0 = 1
         end if
         if(Button(PORTB, 1, 10, 0)) then
            PORTD.0 = 0
         end if
wend
aameer
Full Member level 4
Bangalore
i have worked in mikro C not in this IDE.
But i think it is not necessary to make PORTB=0; as it is not a output port. remove it and check.
hexreader
Advanced Member level 2
England
My guess is that you need to disable the watchdog timer in configuration settings (edit project)
