PIC16F877A project works on emulator but not on chip!
kerden
Junior Member level 3
A magical problem!!!!
hi:
I have edited a project using MCU of PIC16F877A.
it can work well on emluator ICD 1,but when i download on the chip it couldn't
work?
why ???
thank you!
mipedja
Re: A magical problem!!!!
Turn off Watch dog timer, and be sure that you are using right oscillator type.
eltonjohn
Hi is NOT MAGICAL is plain simple..
On pics there are several CONFIGURATION bits that need to be set at the PROGRAMMING DEVICE level .. I mean at the moment when you download your code .These are .the type of oscilator type ,the reset ,brown on .check with a scope if your oscilator works .
cmos babe
Full Member level 4
Dubai
this is not a magical problem because it always happens to me,did you make sure that your MCLR\ pin is connected to Vcc? are you sure that your programmer works well? there are many possibilities...
kerden
Yes .
i have done.
Added after 45 minutes:
CONFIGURATION bits like that:
kerden
i have done.
because it isn't every function doen't work when download to chip besides some.
so it dosn't hardware problem.
Added after 46 minutes:
#include"pic.h"
#define uchar unsigned char
#define uint unsigned int
#define Some_nop(); NOP(); NOP(); NOP(); NOP(); NOP(); NOP();
extern set_inte();
uchar time_chang_flag;
uchar time_over_flag;
uchar set_clock1_flag;
void Key_init(void)
	TRISB |= 0x1f;
	OPTION &= 0x3f;
	RBIE = 1;
void delay(void)
	uint i;
	for(i=6553;--i;)
	continue;
void restart()
	RD1 = 0;
	time_over_flag = 0;
	set_clock1_flag = 0;
	time_buff = 2;
main()
	uchar i,j;
	uchar time_buff;
	TRISD = 0;
	PORTD = 0;
	GIE = 1;
	Key_init();
	time_over_flag = 0;
	time_chang_flag = 0;
	time_buff = 2;
	while(1)
		if(time_chang_flag==1)
			RD2=1;
			time_buff = 0;
		if(time_buff < 1)
			if(set_clock1_flag==0)
				RD1 = 1;
				RD3=0;
				set_clock1_flag = 1;
				INTE = 1;
				set_inte();
		if(time_over_flag==1)
			time_over_flag = 0;
			RD3=1;
			restart();
void interrupt interrupt_job()
	if(RBIF)
		RBIF = 0;
		delay();
		PORTB = PORTB;
		if(RB4==0)
			if(time_chang_flag==0)
				time_chang_flag = 1;
		RBIF = 0;
	if(INTF)
		INTE = 0;//disable int wait clear 8563 alarm
		INTF = 0;
		time_over_flag = 1;
C-Man
Hi
I took a quick look at your code:
   if(RBIF)
      RBIF = 0;this must go after reading PORTB
      delay();not a good idea to use such a long delay inside an interrupt your processor will not be able to do anything else during this
      PORTB = PORTB;check if this is not optimized away by the compiler better use a variable
RBIF = 0;this must go here
if(RB4==0)
      RBIF = 0;
   if(INTF)
      INTF = 0;
      time_over_flag = 1;
By the way you never answered if the code I have posted in your last post is working now ...
best regards
