pic16f877 + keypad + two 7-segment (help me)
suleymanqx
Newbie level 6
Newbie level 6
Hi guys! I need a help, what should I do to send first pressed number to first 7-seg(portb) second pressed number to second 7-seg(portc) ?
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#byte   portb=0x06
#byte   portc=0x07
#define sut1   pin_d0
#define sut2   pin_d1
#define sut3   pin_d2
#define sut4   pin_d3
#define sat1   pin_d4
#define sat2   pin_d5
#define sat3   pin_d6
#define sat4   pin_d7
char tus=0;
char keypad_read()
   output_d(0x00);
   output_high(sat1);
   if (input(sut1))   // 1. sütun okunuyor
      { delay_ms(20); tus=1; }
   if (input(sut2))   // 2. sütun okunuyor
      { delay_ms(20); tus=2; }
   if (input(sut3))   // 3. sütun okunuyor
      { delay_ms(20); tus=3; }
   if (input(sut4))   // 4. sütun okunuyor
      { delay_ms(20); tus=0xA; }
   output_low(sat1); // 1. satýr lojik-0 yapýlýyor
   output_high(sat2); // 2. satýr lojik-1 yapýlýyor
      { delay_ms(20); tus=4; }
      { delay_ms(20); tus=5; }
      { delay_ms(20); tus=6; }
      { delay_ms(20); tus=0xB; }
   output_low(sat2); // 2. satýr lojik-0 yapýlýyor
   output_high(sat3); // 3. satýr lojik-1 yapýlýyor
      { delay_ms(20); tus=7; }
      { delay_ms(20); tus=8; }
      { delay_ms(20); tus=9; }
      {delay_ms(20); tus=0x0C; }
   output_low(sat3); // 3. satýr lojik-0 yapýlýyor
   output_high(sat4); // 3. satýr lojik-1 yapýlýyor
      { delay_ms(20); tus=0xE; }
      { delay_ms(20); tus=0; }
      { delay_ms(20); tus=0xF; }
      {delay_ms(20); tus=0xD; }
   output_low(sat4); // 3. satýr lojik-0 yapýlýyor
   return tus;
void main ( )
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_CCP1(CCP_OFF);
   setup_CCP2(CCP_OFF);
   set_tris_b(0x00);
   set_tris_c(0x00);
   set_tris_d(0x0F);
   output_b(0x00);
   output_c(0x00);
   while(1)
      portb=keypad_read();
create one flag with bit type variable
set the flag to send the first number to 1st 7-segment, and clear the flag to send the second number to 2nd 7-segment.
check the the flag to send the data to 7-segment. if yes===> 1st display On.
No===> 2nd display On,
thank you bro!
Can you write it for me and where I have to write it in code please?
#include <16f877.h>
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#byte portb=0x06
#byte portc=0x07
#define sut1 pin_d0
#define sut2 pin_d1
#define sut3 pin_d2
#define sut4 pin_d3
#define sat1 pin_d4
#define sat2 pin_d5
#define sat3 pin_d6
#define sat4 pin_d7
char tus=0;
int select_seg=1;
char keypad_read()
output_d(0x00);
output_high(sat1);
return tus;
void main ( )
setup_adc(ADC_OFF);
set_tris_b(0x00);
set_tris_c(0x00);
set_tris_d(0x0F);
output_b(0x00);
output_c(0x00);
while(1)
if(select_seg)
if(keypad_read()>0)
Portb = keypad_read();
select_seg=0;
if(!select_seg)
if(keypad_read()>0)
Portc = keypad_read();
select_seg=1;
first pressed number to first 7-seg(portb), second pressed number to second 7-seg(portc)
modify the program like this.
change the while loop and declare the i variable;
int i=0;
while(1)
i = keypad_read();
if(select_seg)
if(i>0)
select_seg=0;
i=0;
if(!select_seg)
if(i>0)
select_seg=1;
i=0;
thank you bro, but it doesn't work. first pressed number writes to portb then freezes
#include <16f877.h>     // Kullanýlacak denetleyicinin baþlýk dosyasý tanýtýlýyor.
// Denetleyici konfigürasyon ayarlarý
#use delay (clock=4000000) // Gecikme fonksiyonu için kullanýlacak osilatör frekansý belirtiliyor.
#use fast_io(b)
#use fast_io(c) //Port yönlendirme komutlarý B portu için geçerli
#use fast_io(d) //Port yönlendirme komutlarý C portu için geçerli
#byte   portb=0x06
#byte   portc=0x07   // C portu "tus" ismine eþitleniyor.
#define sut1   pin_d0 // sut1 ifadesi pin_d0 ifadesine eþitleniyor
#define sut2   pin_d1 // sut2 ifadesi pin_d1 ifadesine eþitleniyor
#define sut3   pin_d2 // sut3 ifadesi pin_d2 ifadesine eþitleniyor
#define sut4   pin_d3 // sut3 ifadesi pin_d2 ifadesine eþitleniyor
#define sat1   pin_d4 // sat1 ifadesi pin_d4 ifadesine eþitleniyor
#define sat2   pin_d5 // sat2 ifadesi pin_d5 ifadesine eþitleniyor
#define sat3   pin_d6 // sat3 ifadesi pin_d6 ifadesine eþitleniyor
#define sat4   pin_d7 // sat4 ifadesi pin_d7 ifadesine eþitleniyor
int i=0;
int select_seg=1;
char tus; // karakter tipinde deðiþken tanýmlanýyor
//*********** Keypad Tarama Fonksiyonu *********
char keypad_read() // Fonksiyon ismi
   output_d(0x00); // D portu çýkýþý sýfýrlanýyor
   output_high(sat1); // 1. satýr lojik-1 yapýlýyor
   return tus; // Fonksiyon "tus" deðeri ile geri döner
/********* ANA PROGRAM FONKSÝYONU********/
void main ( )
   setup_psp(PSP_DISABLED);        // PSP birimi devre dýþý
   setup_timer_1(T1_DISABLED);     // T1 zamanlayýcýsý devre dýþý
   setup_timer_2(T2_DISABLED,0,1); // T2 zamanlayýcýsý devre dýþý
   setup_adc_ports(NO_ANALOGS);    // ANALOG giriþ yok
   setup_adc(ADC_OFF);             // ADC birimi devre dýþý
   set_tris_b(0x00);
   set_tris_c(0x00);   // B portu komple çýkýþ
   set_tris_d(0x0F);   // Yüksek deðerlikli 4 bit çýkýþ, düþük deðerlikli 4 bit giriþ
   output_b(0x00);
   output_c(0x00); // Ýlk anda B portu çýkýþý sýfýrlanýyor
   while(1)  // Sonsuz döngü
    i = keypad_read();
if(select_seg)
if(i>0)
select_seg=0;
i=0;
if(!select_seg)
if(i>0)
select_seg=1;
i=0;
whats happening while pressing the second switch and in second display?
It is better to use portb change interrupt rather than scaning have a look on it
#include <16F877A.h>
#device adc=16
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#use delay(clock=20000000)
#include <LCD.C>
#include <defines.c>
#BIT FLAG = STATUS.RBIF
char key[4][3]= { '1','2','3',
'4','5','6',
'7','8','9',
'*','0','#'};
#int_RB
void RB_isr(void)
BYTE COL;
BYTE temp;
int i,j,k;
delay_ms(20);
COL=PORTB;
bit_clear(STATUS, RBIF);
output_bit( PIN_B0, 1);
if(temp!=COL) {i=0; FLAG=0;}
output_bit( PIN_B1, 1);
if(temp!=COL) {i=1; FLAG=0;}
output_bit( PIN_B2, 1);
if(temp!=COL) {i=2; FLAG=0;}
for(k=4;k<=7;k++){
if( bit_test(COL,k)) {j=k; break;}
j=j-4;
lcd_gotoxy(17 ,1);
printf(lcd_putc , "%c" , key[j]);
delay_ms(500);
void main()
lcd_init();
port_b_pullups (true);
enable_interrupts(INT_RB);
enable_interrupts(GLOBAL);
lcd_gotoxy(1 , 1 );
lcd_putc("character is");
set_tris_b(0xf0);
output_bit( PIN_B0, 0);
output_bit( PIN_B1, 0);
output_bit( PIN_B2, 0);
while(TRUE)
it works fine . In defines file define Registers of pic16f877a to make them use in pic c CSS compiler
LCD on port D and keypad on port b. u can use seven segment instead of LCD.
Nothing heppens. just first pressed digit sends to portb then doesn't any reaction in second pressed digits
#device adc=16
#include <LCD.C>
                         '4','5','6',
                         '7','8','9',
                         '*','0','#'};
#int_RB
void  RB_isr(void)
       BYTE COL;
       BYTE temp;
       int i,j,k;
       delay_ms(20);
       COL=PORTB;
        for(k=4;k<=7;k++){
         j=j-4;
         lcd_gotoxy(17 ,1);
         printf(lcd_putc , "%c" , key[i][j]);
         delay_ms(500);
void main()
   lcd_init();
   lcd_gotoxy(1 , 1 );
   set_tris_b(0xf0);
   while(TRUE)
Thank you bro but I'm not advanced programmer) I'm electrical engineer without programming. So I need a simple code to do this job for making another project with 7-segments.
The anboli's code is perfect for me but it doesnt work properly
Done
#include <16f877.h>
#use delay (clock=2000000)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#byte   portb=0x06
#byte   portc=0x07
#define sut1   pin_d0
#define sut2   pin_d1
#define sut3   pin_d2
#define sut4   pin_d3
#define sat1   pin_d4
#define sat2   pin_d5
#define sat3   pin_d6
#define sat4   pin_d7
char tus,ptus,ekran;
char keypad()
   output_d(0x00);
   tus=0;
   output_high(sat1);
   if (input(sut1))
   if (input(sut2))
   if (input(sut3))
   if (input(sut4))
   output_low(sat1);
   output_high(sat2);
   if (input(sut1))
   if (input(sut2))
   if (input(sut3))
   if (input(sut4))
   output_low(sat2);
   output_high(sat3);
   if (input(sut1))
   if (input(sut2))
   if (input(sut3))
   if (input(sut4))
   output_low(sat3);
   output_high(sat4);
   if (input(sut1))
   if (input(sut2))
   if (input(sut3))
   if (input(sut4))
   output_low(sat4);
   return tus;
void goster_b()
      ekran=tus;
      if(ekran==255){ekran=0;}output_b(tus);
void goster_c()
      ekran=tus;
      if(ekran==255){ekran=0;}output_c(tus);
void main ( )
   setup_adc(ADC_OFF);
   set_tris_b(0x00);
   set_tris_c(0x00);
   set_tris_d(0x0F);
   output_b(0x00);
   output_c(0x00);
   int k;
   while(1)
     keypad();
     if(tus>0)
     k++;
     if(k==1){
     goster_b();
     ptus=tus;
     do{delay_ms(10);keypad();}while(tus==ptus);
     if(k==2){
     goster_c();
     ptus=tus; k=0;
i missed one curly brace in that loop.
so only it getting freeze..
i = keypad_read();
if(select_seg)
if(i>0)
select_seg=0;
i=0;
if(!select_seg)
if(i>0)
select_seg=1;
i=0;
now its work properly..
sure...
