PIC16F877 F877A difference ?
latecomer
Member level 4
USA
f877a
I have a PicStart Plus programmer which can program PIC16F877 but it doesnt have the F877A listed in its list of supported processors , I tried programming the PIC16F877A using a ISCP connector but I'm only able to programme the chip only once, if I try to "verify" I get errors. Can someone tell me whats the difference between the two chips and is there a procedure to program the F877A using the PicStartPlus with only F877 in its list ???
Thanks in advance.
difference pic16f877a
here is the note from microchip telling the differences between 16f8xx and 16f8xxA
good reading!
  • 16f87xa.pdf
voltage comparator on pic16f877a
You can check / upgrade your programmers firmware:
I don't know if that firmware supports 877A-types, but it's worth a try.
If that doesn't help you should contact mirochip.
Mik
difference between pic16f877a and pic16f887
latecomer,
some time ago, i asked my local MChip representative what were the diferences for the "A" versions of the chips.
He simple answered me that the manufacturing process was using a thinner wafer now.
regards
asena
pic16f877a differences
the "A" contains a voltage comparator that the "not A" doesnt have too.
how many program block have pic16f877
hai,
is there any difference is there???
bye
picstart plus with pic16f877
Hi!
There is also a programming difference between "A" and non A
versions :
"Microchip have changed the flash writing sequence so that it writes in blocks of 4 words rather than single words"
Bootloaders from "microchipC.com" are different.
Regards
difference+between+pic16f877+and+pic16f877a
last release of ICPROG also supports it.
Only it can't supports "verifying during programming" optio for the reason of the 4 words block
pic16f877a pic 16f877 difference
iam also having the sane doubt wheather i can use pic 16f877a programer for programing pic 16f877
pic16f877 migration pic16f877a
Pic 16f877A is having 2 Analogue Comparators,which 877 does not have. Moreover,for internal structural difference, to program both, 2 seperate programming softwares to be included in the main programming software. One will not suffice to program both. Thanks.
comparaison pic16f877 et pic16f877a
Big difference is 877A only in market :)
Do you get 877 in market? I not get at all.
