pic16f877 driver motor stepper
lats
Full Member level 4
Full Member level 4
reseting a pic
hello,
I'm designing a project wherein I'm counting some pulses from a proximity sensor. Whenever there is a power failure I have to store the last value in memory(eeprom). I'm bound to NOT to use any battery. So I'm using a bigger condensor in power failure so that it provides enough enegy & time to let me store the value. I have put approx. 11,000 uF. This is working fine. But when there is a power failure just for a fraction of time (let's say 1 second) & power resumes the controller hangs up. I tried putting a seprate 5 volt supply(without condensors) on MCLR circuit but the things became worst. I'm attaching the MCLR circuit. What can I do to make the things proper.I'm using PIC16F877A.
Thanks for giving me your precious time.
Re: Resetting a PIC
1. If you don't have very many proximity events, you could write every one of them to the EEPROM. Then you wouldn't need a big capacitor. Of course, the caveat is that the EEPROM has a limited number of write cycles.
2. Try attaching a reset supervisor chip, such as MAX809, MCP809 or MCP130.
Re: Resetting a PIC
Can you show us your full power-supply schematic?
Reactions: hieu_dh
    lats
    hieu_dh
Re: Resetting a PIC
Thanks for replying.
Kender your solution is not possible cause the pulses are very fast.
secondly what are the benefits of using reset supervisor chips? I'm new to them.
CMOS thanks once again. I have attached the circuit diagram please have a look. I'm using BC548 transistor section on PIN 33 of controller to detect the power failure.
Re: Resetting a PIC
I would suggest you use two 1N5819 diodes as shown in attached schematic near 7805 to prevent 4700uF caps from discharging through it when power fails. Change bax capacitor to electrolytic 10uF.
And as Kender suggested, use Voltage supervisor for reset. Is brown-out detect enabled in PIC fuse settings?
Try to capture waveforms of 5V supply and power-supply failure detector output when there is short power failure.
Why don't you use switching regulator like LM2575/LM2576? That way you dont have to use 7812 at all.
    lats
Re: Resetting a PIC
The problem could be generated with LVP pin when LVP is enabled.
Re: Resetting a PIC
From my experience, doing the same thing, I can tell you not to use external RC reset circuit . Activate PWRT and BOR. Under BOR voltage controller will be held at reset state. BOR voltage is about 4V, so with this big capacity /11000uF/,I think you'll have enough time to write eeprom,until Vdd reaches 4V.
Re: Resetting a PIC
Could this be because the EEPROM write is still in progress?
