PIC16F819 12v to 220v inverter failed
d@nny
Full Member level 5
i have insert my 50Hz pic16f819 in inverter for dc12v to 220vac. Amazing. The 50hz increased to 200 hertz and when i tried to check output with analouge metre it burns and the second shous at 250 to 30 volts with very trimbling pin. Why frequency increased to 200 hertz?
Transistors are TIP741 4 transistors 2 each side.
below the pic what i have actually done. consider each transistor 2 as i have combined their all three pins together.
now it is working with the following code. But is it ok 80% duty cycle i mean 8ms? or it should be low?
processor PIC16F819
#include <p16f819.inc>
__CONFIG _CP_OFF & _WRT_ENABLE_OFF & _CPD_OFF & _CCP1_RB2 & _LVP_OFF & _BODEN_ON & _MCLR_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_IO
J equ 20h
K equ 21h
org 0
goto main
main:
banksel OSCCON
movlw B'01110000'
movwf OSCCON
banksel TRISB
movlw B'00000000'
movwf TRISB
banksel PORTB
Flasher:
bcf PORTB , 1
call delay10ms
bsf PORTB , 0
call delay8ms
nop
nop
bcf PORTB , 0
call delay10ms
bsf PORTB , 1
call delay8ms
goto Flasher
fin:
goto fin
delay2ms:
movlw D'2'
movwf K
clrf J
delay1:
nop
decfsz J , f
goto delay1
delay2:
nop
decfsz J , f
goto delay2
decfsz K , f
goto delay1
return
delay8ms:
movlw D'8'
movwf K
clrf J
delay11:
nop
decfsz J , f
goto delay11
delay22:
nop
decfsz J , f
goto delay22
decfsz K , f
goto delay1
return
end
