PIC16f73 programming with Real ICE/ ICD2
ashwini_extc
Newbie level 2
I would like to program 16f73 by either real ICE or ICD2. Do any one cal me the circuit diagram?
wp100
Advanced Member level 5
Prime Meridian
Those programmer are high end devices - do you really need such a costly solution ?
The diy Pickit2 covered all over this forum will program it if you use its stand alone program - it will not work from within MPLAB.
Alternatively, use one of the many other pic chip that the Pickit2 or other serial /parallel programmers will burn
Dont forget the ICD2 and PK2 both need a pic chip to be program up to make them work.
Again search this form for details.
Midrange/Standard Devices
>> Versions of devices are supported by PK2 program 2.61
PIC12F609 PIC12HV609
PIC12F615 PIC12HV615
PIC12F629 PIC12F635# PIC12F675 PIC12F683#
PIC16F610 PIC16HV610 PIC16F616 PIC16HV616
PIC16F627 PIC16F628 PIC16F639
PIC16F627A PIC16F628A PIC16F648A
PIC16F630 PIC16F631 PIC16F636# PIC16F676
PIC16F677 PIC16F684# PIC16F685# PIC16F687#
PIC16F688# PIC16F689# PIC16F690#
PIC16F72+
PIC16F73+ PIC16F74+ PIC16F76+ PIC16F77+
PIC16F716
PIC16F737+ PIC16F747+ PIC16F767+ PIC16F777+
PIC16F785 PIC16HV785
PIC16F84A PIC16F87# PIC16F88#
PIC16F818# PIC16F819#
PIC16F870 PIC16F871 PIC16F872
PIC16F873 PIC16F874 PIC16F876 PIC16F877
PIC16F873A PIC16F874A PIC16F876A PIC16F877A
PIC16F882#
PIC16F883# PIC16F884# PIC16F886# PIC16F887#
PIC16F913# PIC16F914# PIC16F916# PIC16F917#
PIC16F946#
ashwini_extc
Newbie level 2
I am using MPLAB V8.5. I have Real ICE/ ICD2. I need circuit diagram to program the PIC16F73 with the same. I have connected 100Ohm resistor in series with PGC and PGD. The MCLR bar connected by 100Ohm resistor in series and 10K pullup and getting the Voltage caution that is with the thread.
g_shyam1682
Full Member level 4
Udaipur-Rajshan-India
Hi friend
I am using MPLAB V8.5. and I use ICD3 as well as PicKit 3 for In Circuit Serial Programming since last one year.
Remove these series resistor from PGC, PGD as well as from MCLR.
Direct connect this three line of PIC16F73 with ICD2/ Real ICE.
as well as Vdd and GND line of Pic16F73 are also connect with ICD2 Directly.
Apply +5V Vdd externally to PIC16F73(Target Device) at programming time.
In MPLAB IDE, Select from menu Programmer ==> Select Programmer ==> Real ICE.
Hope this is help you
Shyam
