PIC16F628A Need to Generate 38.3KHZ PWM Burst of 10ms for TSOP1838
asking
Full Member level 5
Full Member level 5
Hello
I am using MikroC Code for generating PWM signal Code is :-
void main()
     TRISB = 0;  // pins are output, GP3 always input
     PWM1_Init(38000);
     PWM1_Start();
     PWM1_Set_duty(120);
while(1){}
I got the 38.2KHZ signal of PWM on my CRO. I need Burst of 38.3KHZ signal with 10ms gap. How to generate it ? is it possible with one microcontroller or do i need to use external switch to on/off signal from MCU ? Please help me.
hi
it's possible to do this with only microcontroller
you can try this
Code C - [expand]
8
9
10
11
12
13
void main()
     PWM1_Init(38000);
     PWM1_Set_duty(120);
     while(1)
         PWM1_Start();
         Delay_ms(10);
         PWM1_Stop();
         Delay_ms(10);
if you are doing other things too in the code, it probably is a good idea to move the PWM part in timer interrupts
