PIC16f1527 UART baudrate formula
ragav4456
Full Member level 4
Hi friends
I doubt in PIC uart baudrate formula calculation in Program.
BRGH=1;BRG16=1; kindly send the sample code.
Sample code for PIC16f877A ic UART
int X;
	/* calculate and set baud rate register */
	/* for asynchronous mode */
	tmp = 16UL * baud;
	X = (int)(FOSC/tmp) - 1;
	if((X>255) || (X<0))
		tmp = 64UL * baud;
			return 1;	/* panic - baud rate unobtainable */
		else
			BRGH=0;	/* low baud rate */
how to change this code for pic16f1527 ic?
Baudrate formula depends upon this bits BRGH=1; BRG16=1;
BRG16 meaning?
See the images.
I have doubt in 57600 is 16 bit baudrate or 8 bit baudrate.?
See this table. What is your Fosc?
For Fosc = 20 MHz, SYNC = 0, BRGH = 1, BRG16 = 1, and baudrate 57600 bps, SPBRG value = 86. So, it is 0086. SPBRGH = 00, SPBRGL = 86.
FOSC-20MHZ Baud rate-57600
SPBRG= 86; means UART not working. what is the reason?
the first post is automatic calculation of SPBRG=X.
UART output is varied. My program starting bit is 35, but output is 82 or 80 and some other else.
I am testing in HARDWARE.
just change associate register.
associate register means?
