PIC12F683 GPIO pin reading problem
technocrate
USA
Hello,
I am building a very small circuit with PIC12F683 which will drive two small 5V relays from its timers.
The time interval will depend on the one of 4 settings on DIP Switch connected to GP4 and GP5 (GP4 = Switch0 and GP5 = Switch1).
I am using HI-Tech PICC compiler Lite Version (9.83).
I am having syntax problems at "IF{ " when compiling the following lines:
// Main loop
while(1)
//Read Input Switches
//SW1 SW0
// 00 = AUTO MODE with PIR
// 01 = Fix Mode: Shot every 10 Sec
// 10 = Fix Mode: Shot every 30 Sec
// 11 = Fix Mode: Shot every 1 Minute
// Read the DIP switch settings
If(SW1==0 && SW0==0){
// AUTO MODE
// This would be external interrupt trigger driven code
// Turn Power ON
// POWER = 1;
// Delay 3 usec
__delay_ms(3000);
// Take a shot
// SHOOT = 1;
// Wait for it to be saved on the SD Card
__delay_ms(3000);
Thank you for your help.
milind.a.kulkarni
Advanced Member level 3
Bangalore
i think it is case sensitive you type "IF" mostly you need try typing... "if"
Good Luck
