[PIC] PIC UART communicaion with PC
Naseer Ahmed
Newbie level 5
Islamabad, Pakistan, Pakistan
Hello dear friends,
Please guide me against the following problem:
I am trying to develop uart communication between PIC 16F877A (20 MHz crystal) and PC using hyper terminal.
I wrote the following simple code in mikroc Pro v.6.5.0 compiler to run:
char RS;
void main()
   TRISC = 0xF0;
    Uart1_Init(9600);
  while(1)
      if (uart1_data_ready()==1)
        RS = uart1_read();
        uart1_write(RS);
But it is not working.
I have tested the serial cable and MAX 233 IC by shorting TX and Rx together and these are working properly.
The protocols are also same:
Baud rate of both PC and code are 9600 bps each
data bits 8
No parity bit
stop bit 1.
Can you kindly tell the point of problem?
Naseer Ahmed
Hello dear friends,
char RS;
void main()
   TRISC = 0xF0;
    Uart1_Init(9600);
  while(1)
        RS = uart1_read();
        uart1_write(RS);
data bits 8
No parity bit
stop bit 1.
Naseer Ahmed
Could you update your uart function and interrupt routine?
