PIC microcontroller is not working
chanchal.chauhan
Full Member level 4
Full Member level 4
Hyderabad, India
Hello Guys,
I am working in PIC18F1330 microcontroller. When I am including LED blinking program my o/p control voltage is varying. I used current limiting resistor.
4.0V ----!>!-------/\/\/\/\/\----- I/O PORT
LED 1K
Please help me to solve the problems.
Thanks & Regards
Chanchal
Probably you do not have sufficient delay between your led turning on and off so your ' slow' meter is giving fluctuating readings.
If that is not the cause, then it would be better if you could post your code and circuit diagram.
My Vdd voltage is varying 0.1v when LED is blinking & Vdd-0.1v when LED is ON.
Is the problem in power supply?
Is the Micro controller unable to sink or source the current?
#1 check the power supply separately.
#2 put a current limiting resistor in series with the LED (1 kOhm resistor is good)
#3 check the microcontroller in an easy task, I/O, LED blinking...etc
You probably do not have enough filtering on the psu but to be sure you need to post your circuit diagram of the pic and psu
Apart from the voltage fluctation is the program running ok and the led flashing correctly?
Place 0.1uf capacitor across your supply pins (Vdd & Gnd) to bypass power supply noise.
Second, whats the time delay you're using?
