sabin14
Junior Member level 3
- Joined
- Mar 5, 2013
- Messages
- 30
- Helped
- 11
- Reputation
- 22
- Reaction score
- 11
- Trophy points
- 1,288
- Location
- Kerala,India
- Activity points
- 1,431
Pic MikroC error "PC out of scope"
When I try to debug my project in Mikroc it show the error "PC out of scope".
when I comment the following line everything works fine.
error = Soft_UART_Init(&PORTC, 0, 1, 1200, 0);
Deatils:
Mcu : pic 18F4520
Xtal : 11.0592 Mhz
Here is the 8bit lcd library used in the code: View attachment __Lib_Lcd8.zip
Please help me to correct the code.
Here is the complete project:View attachment project_pic18f4520.zip
Here is my code:
Deatils:
Mcu : pic 18F4520
Xtal : 11.0592 Mhz
Here is my code:
// LCD module connections
sbit LCD8_RS at RD4_bit;
sbit LCD8_RW at RD5_bit;
sbit LCD8_EN at RD6_bit;
sbit LCD8_D7 at RB7_bit;
sbit LCD8_D6 at RB6_bit;
sbit LCD8_D5 at RB5_bit;
sbit LCD8_D4 at RB4_bit;
sbit LCD8_D3 at RB3_bit;
sbit LCD8_D2 at RB2_bit;
sbit LCD8_D1 at RB1_bit;
sbit LCD8_D0 at RB0_bit;
sbit LCD8_RS_Direction at TRISD4_bit;
sbit LCD8_RW_Direction at TRISD5_bit;
sbit LCD8_EN_Direction at TRISD6_bit;
sbit LCD8_D7_Direction at TRISB7_bit;
sbit LCD8_D6_Direction at TRISB6_bit;
sbit LCD8_D5_Direction at TRISB5_bit;
sbit LCD8_D4_Direction at TRISB4_bit;
sbit LCD8_D3_Direction at TRISB3_bit;
sbit LCD8_D2_Direction at TRISB2_bit;
sbit LCD8_D1_Direction at TRISB1_bit;
sbit LCD8_D0_Direction at TRISB0_bit;
// End LCD module connections
sbit ACCIDENT_KEY at RD1_bit;
sbit GPS_KEY at RD0_bit;
char error, byte_read;
void Display_Risk();
void Gps_Data();
void Send_Sms();
void Accident_Action();
unsigned char time = 60;
char temp[3];
//// GPS Variables
int i = 0;
int received = 0;
char DataType[] = "GPXXX";
char NMEA[] = "$xxxxx,xxxxxxxxx,xxxx.xxx,x,xxxxx.xxx,x,x,xx,x.x,xxx.x,x,xx.x,x,,*xx";
char receive;
// End Variables
//Lcd strings
char msg1[] = "RISK WARNING";
char msg11[] ="SYSTEM";
char msg2[] = "INITIALIZING ";
char msg3[] = "GPS";
char msg31[]= " MODEM";
char msg4[] = "GSM";
char msg5[] = "ACCIDENT ZONE";
char msg6[] = "HAIRPIN CURVE";
char msg7[] = "ACCIDENT DETECTED";
char msg8[] = "LOCATION:";
char msg9[] = "SMS SENT";
void main(){
TRISB = 0x00;
PORTB = 0;
TRISC = 0xff;
TRISD = 0b00000011;
Lcd8_Init();
Lcd8_Cmd(_LCD_CLEAR);
Lcd8_Cmd(_LCD_CURSOR_OFF);
Lcd8_Out(1,3,msg1); //Message for LCD
Lcd8_Out(2,6,msg11);
Delay_ms(3000); //3000
Lcd8_Out(1,3,msg2); //lcd message
Delay_ms(2000);
Lcd8_Out(1,3,msg2); //Message for LCD
Lcd8_Out(2,5,msg4);
Lcd8_Out_Cp(msg31); //initializing gsm modem
Delay_ms(2000);
Lcd8_Out(2,5,msg3);
Lcd8_Out_Cp(msg31); // initilizing gps modem
Delay_ms(2000);
Lcd8_Out(2,5,msg4);
Delay_ms(2000);
Lcd8_Out(2,5,msg3);
Delay_ms(2000);
while(1) {
byte_read = Soft_UART_Read(&error);
if (error){
else{
Lcd8_Chr_CP(byte_read);
Lcd8_Cmd(_LCD_SHIFT_LEFT);
if(byte_read=='A')
Display_Risk();
if(time<1)
time = 60;
ByteToStr(time,temp);
Lcd8_Out(1,3,"SCANNING") ;
Lcd8_Out_CP(temp);
time--;
Delay_ms(90);
if (error){
else{
if(byte_read=='A')
Display_Risk();
Accident_Action(); //call functio to check key press
Delay_ms(910); //985
void Display_Risk(){
Delay_ms(90);
if (error){
else{
//Lcd8_Chr_CP(byte_read);
//Lcd8_Cmd(_LCD_SHIFT_LEFT);
if(byte_read=='1') {
Lcd8_Out(1,1,msg5); //accident zone lcd
Delay_ms(6000); //add speed control here
if(byte_read=='2') {
Lcd8_Out(1,1,msg6); //accident zone lcd
void Accident_Action(){
if(!ACCIDENT_KEY){
Delay_ms(20);
if(!ACCIDENT_KEY){ //accident switch routine
Lcd8_Out(1,1,msg7); //Message for LCD :accident
Delay_ms(2000);
Lcd8_Out(1,3,msg8); //Message for LCD : location
Delay_ms(1000);
Gps_Data();
Lcd8_Out(1,1,msg9); //Message for LCD : sending sms
Delay_ms(2000);
Send_Sms();
if(!GPS_KEY){
Delay_ms(20);
if(!GPS_KEY){ //gps switch routine
Delay_ms(1000);
Gps_Data();
void Gps_Data(){
UART1_Init(9600);
while(1) {
if (UART1_Data_Ready() == 1) {
receive = UART1_Read();
if (receive == '$')
received = 0;
do{
UART1_Read_Text(DataType, ",", 10); // Capture GPXXX word
received = 1;
} while(received == 0);
// If it is GPGGA Data, then acquire it.
if ((DataType[2] == 'G') && (DataType[3] == 'G') && (DataType[4] == 'A'))
received = 0;
do{
UART1_Read_Text(NMEA, "*", 100); // Stop at *XX checksum data
received = 1;
Lcd8_Out(1,1,NMEA );
Delay_ms(4000);
break;
receive = "x";
void Send_Sms(){
UART1_Init(9600);
UART1_Write_Text("AT");
Delay_ms(100);
UART1_Write_Text("AT+CMGF=1");
Delay_ms(100);
UART1_Write(0x0D); //enter
UART1_Write_Text("AT+CMGS=");
Delay_ms(100);
UART1_Write(0x22);
Delay_ms(100);
UART1_Write_Text("+918496829433");
Delay_ms(200);
UART1_Write(0x22);
Delay_ms(100);
UART1_Write(0x0D); // Enter
Delay_ms(100);
//UART1_Write(0x22); //test by commenting it later
UART1_Write_Text("@rws.u ");
UART1_Write_Text(NMEA);
Delay_ms(600);//add more message parameters here************
UART1_Write(0x22);
Delay_ms(100);
UART1_Write(26); //Ctr +Z --send
Delay_ms(200);
