annna
Member level 2
can anyone help me out.. I want to make a PIC programmer which can work on laptop. I have a serial port on my laptop. So can anyone suggest me any kind of schematic or something...... I will be really thankfull
Note: This feature currently requires accessing the site using the built-in Safari browser.
can anyone help me out.. I want to make a PIC programmer which can work on laptop. I have a serial port on my laptop. So can anyone suggest me any kind of schematic or something...... I will be really thankfull[/QUOTE
Dear Friend
Most of laptops serial port output below 12v that is why reason you can't do that
solution.... supply external 12v supply using external cct to your programmer
Thank you sanjubluerock3 for the link.looks good and easy to use for zif programing.
Can this programmer be made with 18f4550, which is available to me and is half priced compared to 18f2550 which is not available at this time.
Both of the Mcu are said to be identical inside. will it be OK to use pin functions and not the pin numbers.
..Welcome Palma to EDA board. What more can we expect when we have the author of the file here. Your files are additionally good as i can see support for 30F series and EEproms too.Hello, I'm PALMA, if anyone needs help with the design, I can help Regards
